Not mine, neighbour, went out on Monday it will have been cold but probably about zero degrees.
Started up I think all ok.
Drove for a bit then the power steering went heavy and then battery warning on the dash then the engine cut.
He bought a new battery and fitted that, it was all good for most of the day then the same thing happened.
I towed it home on Friday, there were battery lights but turn the key and they dimmed.
So I thought pas is electric which explains why that went dead with the loss of power, the lad charged it up over night and in the morning it started up ok and is running at 13.8v
So the question is. What can the problem be?
I do notice the key feels a little bit loose as in the switch notches seem a little less notchy so I wonder could the ignition switch be on its way ? The other thought was the alternator brushes or internals or the free wheel pulley on it if it has a clutch type might be stiff? Stuff to look at really but I thought I'd any of you lads are familiar with this problem it would save me a headache..
Cheers guys
I've done a quick search
