Hi all. I am working through an issue on my MK1 Transit Connect. It is a 2009 1.8 TDCi.
First issue started when injector 1 started leaking and van was chugging and eventually a ton of smoke burst out the exhaust and van stalled. Stripped injector roadside, cleaned it up and just managed to get home.
New copper seal fitted and new stretch bolt. Now engine is ticking over quite sweet, even better than before. No codes at all like when it happened. But now it's kicking out a lot of smoke still. I do admit the injector seems to be leaking from the injector pipe so I will look into that further.
I was wondering if a secondary problem occurred and I thought to check turbo pipes. The smoke is bellowing from the turbo and out of the air filter box. I removed the pipe from the turbo and it has quite a build up of thick black oil.
I am going to redo all the injector seals and see if that clears up the smoke issue. And also fix the small leak from the pipe.
Do any of you think it could be the turbo or could just a relatively small injector leak cause SO much smoke?
Happy to fit a new turbo but not a 2 minute job so would like some opinions please.
Thank you!
