Ford transit connect 2016 1.6 engine search!!!
Postby ChrissyG93 » Fri Jan 24, 2025 9:25 pm
hi all
i have 2016 Ford transit connect 1560cc with a TZGA engine and im looking for a replacement.
Done a bit of research and i know i cant have a T1GA i think it is and the fuel systems are different and cant be interchanged easily. #
looking at getting a donor car from copart but can find anyway of knowing which 1560cc it has in it with out having the V5 and you only get the V5 after you have purchased it, if it has one.
my engine code is FYXXXXX
any advice or suggestions
ChrissyG93
Re: Ford transit connect 2016 1.6 engine search!!!
Postby Altransit » Fri Jan 24, 2025 10:35 pm
Same 1.6 TDCi engine is fitted to the Mk3 focus 2011-2015, plus a few other non-Fords. Later versions use the similar 1.5 engine, but it may not be interchangeable :?
