Today, driving 2 hours to our powder coater's shop to pick up the newly signal red powder coated custom front coil springs.. then driving back 2 hours to our performance shop to have them take a look at the spring and set up a date to get these installed..
yesterday, had the shop install 2 new trans mounts on the van. All that's left is the coil springs, and rear camber plates.. amazing after nearly 4 years of finding parts for the van, some successful while most not so successful, we've nearly and almost come to the end of our build.. The only thing left is the front air dam and put the van on at least 2 racetracks that will allow us to drive the van on their tracks.. even with all the negative and very few positive comments.. we've struggled to get this completed.
As a reminder and not sure you blokes would be able to order a set of our springs, but just in case you can, here's how you go about doing that.
log Coil Spring Specialist (
https://www.coilsprings.com) and submit and email or "request a quote" form there and within the drop down.. type in "flord Performance" coil springs for a 2019-2023 transit Connect. These will arrive as either powder coated black or powder coated grey.. the front springs are stock ride height, but are 20% stiffer than the factory springs. The rear springs are 2'' shorter and the same 20% stiffer. When replacing springs, you will need to also replace the upper and lower rear perch mounts and perch bushings, which will run you 200.00 USD for the full set. The springs will run you 1,000.00 USD for the set (shipping not included).
The best way to describe these springs is that they are like preset or preloaded springs or are like coilover without the center mounted shocks. Our main objective was to create a leveling spring set that retains the towing and hauling capabilities but at a lower ride height.
