Clock
Clock
Postby mile eater » Sat Jan 12, 2008 11:37 pm
Hi just wondering if any body else has a problem with there clock, i have an 06 '06' connect and the clock loses time. Taken it to 2 dealers who dont know whats wrong.
mile eater
Re: Clock
Postby coconut » Sat Jan 12, 2008 11:44 pm
Is it the one in the instrument cluster?
coconut
Ford Technician
Re: Clock
Postby mile eater » Sat Jan 12, 2008 11:47 pm
Yes
mile eater
Re: Clock
Postby coconut » Sat Jan 12, 2008 11:52 pm
Lots of problems with the clusters, most likely that :?:
coconut
Ford Technician
Re: Clock
Postby mile eater » Sat Jan 12, 2008 11:55 pm
Ill get another dealer to look at and suggest it could be a faulty cluster.
mile eater
Re: Clock
Postby V184 » Sun Jan 13, 2008 1:59 pm
mine does it as well. Also you cant get the trip meter up was told when it was in warrenty there was no cure, was at another dealer having the mk7 sorted and mentioned it to him and told its common fault which dont help as its now on 160,000 miles that what lets Fords down the backup, they also said theres a recall on the front wheel bearings anyone know if this is the case ?
V184
Re: Clock
Postby coconut » Sun Jan 13, 2008 7:25 pm
There is a recall to replace the 2 front wheel bearing, the number is 7S091, if you want to send me your chassis number, I can check to see if it is needed :D
coconut
Ford Technician
Re: Clock
Postby advance » Mon Jan 14, 2008 10:29 pm
hi
mine also looses time,and sometimes if you try to open the load bay it locks straight away??
does this wheel bearing recall cover 53 year models???
The opinions expressed here are of the poster
Opinions may go down as well as up.
Opinions may be recorded for security and staff training purposes
Your home may be at risk if you take any notice of the rubbish printed
CONNECTTDCI+boxer120+120lxmk7
advance
Re: Clock
Postby coconut » Mon Jan 14, 2008 11:22 pm
The recall was for build dates from 4/6/2005 to 19/7/2005 so yours should be ok :D but if you want to PM me your chassis number I can check to see if there is any other outstanding recalls for you :wink:
The load bay locking, is the rear plylined or got any racking? as this is the most common problem with screws going through wiring looms!!
coconut
Ford Technician
Re: Clock
Postby belly » Thu Jan 17, 2008 11:37 pm
could you check mine pls coconut :D pm sent 8)
belly
Kaiser Chief
Re: Clock
Postby coconut » Sat Jan 19, 2008 9:20 pm
Done and pm'd you :mrgreen:
coconut
Ford Technician
