Lack of power
Lack of power
Postby Turbo Tim » Fri Mar 14, 2008 7:37 pm
Started a new topic,been through everything,pump saying timing out of range, checked timing static ok,put small electric pump in line and a clear pipe,all pipes bypassed from the large feed pipe that runs front to back, without pump running i have small air bubbles in the system when engine is running, put pump on and I have air serges,turn engine of but pump still running no air,no signs of leaks and a full tank of fuel,thoughts are welcome.Regards Tim :?
Turbo Tim
Re: Lack of power
Postby coconut » Sat Mar 15, 2008 10:09 pm
I think it sounds like a internal fault with the pump, did you use clear pipe on the return? if so was there any air in that?
coconut
Ford Technician
Re: Lack of power
Postby Turbo Tim » Sat Mar 15, 2008 10:15 pm
Hi didn't put clear on return as run out of pipe,where would the air come from,that is going into the pump,regards Tim :?
Turbo Tim
Re: Lack of power
Postby coconut » Sat Mar 15, 2008 10:32 pm
Where was you connecting the pipe to at the rear? was it push fit or jubilee clip round it?
coconut
Ford Technician
Re: Lack of power
Postby Turbo Tim » Sat Mar 15, 2008 10:36 pm
all pipes were jubilee ,the large feed pipe(steel) at bulk head was the starting point, through filter onto pump, Cheers
Turbo Tim
Re: Lack of power
Postby coconut » Sat Mar 15, 2008 11:37 pm
If you can get a long length, it will be worth doing it from the tank and see if there is air in it (process of elimination unfortunately) or have a seperate supply (can in passenger seat) and see if it makes any difference :?
coconut
Ford Technician
