re 2003 ford connect TDDi 220 75 ps
Postby connectvanman » Tue Aug 12, 2008 2:07 am
Hi anyone help with 2003 ford connect TDDi 220 75 ps had a new fob a while, all worked great till the other day went to close door locks ect and nothing happened. Thought would see if need reprogramming done the sit in van with all doors shut and turn the key of / on 8 times quickly which worked fine when 1st programmed new fob. tried various combinations ie off / on 8 times on / off 8 times adding 1 more tur ech time but door locks just would not cycle. Have to open and shut each lock individually now, and when you push door lock handles only that door locks. Anyone had the same or any advice cheers.
connectvanman
Re: re 2003 ford connect TDDi 220 75 ps
Postby MrMPuk » Tue Aug 12, 2008 8:25 am
Sounds like you need to check the fuses for the central locking.
Postby Frag » Thu Aug 14, 2008 9:13 pm
So no central locking now?
Fuse probably popped,In a awkward place though.
Gonna have to drop fuse box out,its in the back hidden between wiring & connectors :wink: .
Frag
Ford Technician
Postby connectvanman » Mon Aug 18, 2008 11:26 pm
Cheers for that loosened fuse box and twisted to view rear replaced 20 A fuse seems ok for now have to wait see what caused it thanks
connectvanman
Postby connectvanman » Wed Aug 20, 2008 12:41 am
Only lasted a day blew fuse on back of board again when locking or unlocking with fob got a short somewhere any help agh!
connectvanman
