Hi all,
I have had a Transit Connect from new and its now 4 and a half years old with 117,000 on clock. We use it for our cleaning company.
It was always serviced by Ford until its last service at 105,000 miles - and then a local fast service depot serviced it. Two months ago now the driver was driving the vehicle and the oil light came on. The driver stopped. A Roadside Breakdown company were called out - they said the filter was loose and the oil filter seal was worn. He tightened it up - with his hand and put new oil into engine. Then he put on the sheet that the oil filter needed to be changed the next day.
Our driver drove off and ten miles down the road the engine made a loud noise and he stopped. He then recovered the vehicle to Ford Garage who said the engine needed replacing. The van has been in the Ford garage yard since.
We are looking at taking legal action against the servicing garage, but may look at taking action against the roadside breakdown company.
Does anyone know at what pressure the oil light comes on at? Would the engine have failed at this point?
Would an oil filter come loose under normal circumstances.
Speaking to a mechanic friend he thinks the pressure light only comes on at a very low pressure and the engine would have failed then. The reason the roadside repair guy didn't notice it was because the engine was cold at time he started and when the engine got hot then the fault became apparent. Is this correct?
Who would you sue?
Any advice would be much appreciated.
Regards
Tim
