Thanks for the reply, much appreciated.
Its a long running saga, i have another thread running if you have time for a look
Have now located my problem, the small ends have worn/ damaged creating what sounds like a top end rattle. Also down on compression because of it. Can physically rotate piston and its sitting slightly lower than No2
. Hoping this is whats lost the compression rather than bore damage. Checking bore dimensins with micrometers once pistons are out.
Probably looking to get a replacement van while this work is carried out. Almost glad the engine is coming out, much better to work on. Never agreed with the removing big ends with the engine in, so much harder to do and easier to make mistakes.
