RADIO SWAP
RADIO SWAP
Postby gaz68 » Sun Aug 26, 2012 6:44 pm
: hello,i have just found a radio/cd player that was fitted to my old courier van,i hoped to fit this to my 55 plate connect but when i pulled out my ford unit from the connect it had 3 block connecters fitted where as my older unit just has the 1,can you buy a fitting to join all 3 together so it works ?,cheers gaz
gaz68
Re: RADIO SWAP
Postby paul2012 » Sun Aug 26, 2012 7:09 pm
gaz68 wrote:: hello,i have just found a radio/cd player that was fitted to my old courier van,i hoped to fit this to my 55 plate connect but when i pulled out my ford unit from the connect it had 3 block connecters fitted where as my older unit just has the 1,can you buy a fitting to join all 3 together so it works ?,cheers gaz
what year is your old courier van ?
On the connects from 2003 - 2006 the stereos normally have 2 connecters for stereo (unless it has steering column controls for stereo fitted)
1 connector will be for Power (12v+ Batt, 12v+ Ign, ilumination, Keycode, ground)
1 connector for speakers (front Left, front Right)
1 connector for stereo controls on steering column.
If you can upload a pic of back of the stereo you want to fit showing the connection socket, I will be able to give you instructions on how to install it into your connect
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
