Transit Connect T230 LWB TDCI (Misfire, white-grey smoke,)
Postby Barker1985 » Sat Sep 22, 2012 9:24 pm
I have a transit connect t230 1.8 tdci which is misfiring and smokes white-grey. I have put new injectors in cleaned fuel lines checked pipes for splits new fuel fillter, air fillter, any suggestions? Could it be the fuel rail?
Barker1985
Re: Transit Connect T230 LWB TDCI (Misfire, white-grey smoke
Postby Altransit » Sat Sep 22, 2012 10:17 pm
Were the new injectors coded to the ECU :?:
Postby dieselboy1978 » Sat Sep 22, 2012 10:45 pm
Fuel rail no.
Are these injectors from a genuine Dlephi Agent or copy or second hand.
I would be re checking injectors or checking the switching time (milli seconds) on the injectors.
If they are 100% ok then i would be removing the high pressure fuel pump. Possible fault could be the venturi or the relief valve.
Bank account emptied by
DELPHI
dieselboy1978
Postby gt_addict » Sun Sep 23, 2012 12:46 am
Camshaft or crank sensors. Cheap options to start with at around £20 each.
gt_addict
Postby Barker1985 » Sun Sep 23, 2012 8:36 am
We have programmed the injectors to the ecu got the injectors from gap heds autoparts Birmingham my old ones reconditioned.
I have loads of fuel pressure from pump.
So first I should buy a:
New crank sensor
New camshaft sensor
Could the timing be out a little?
Put in order what I should do first?
Cheers Richard
Barker1985
Postby Barker1985 » Sun Sep 23, 2012 8:39 am
This is we're I did my injectors.
  GAPHEADS & AUTOPARTS
1566 Pershore Road, Stirchley, Birmingham, B30 2NH
TELEPHONE ENQUIRIES
Cylinder Head: 0121 486 2740
Injectors & General: 0121 247 0516
Barker1985
Postby dieselboy1978 » Sun Sep 23, 2012 11:27 am
If the vehicle runs it isnt camshaft or crankshaft sensor.
If camshaft sensor fails vehicle will onky fire and cut out or not run at all.
Working as a diesel fuel injection specialist i would be removing injectors and sending to a delphi diesel agent and getting injevtors tested on the the authorised CRiPC test bench.
DELPHI
dieselboy1978
Postby Barker1985 » Sun Sep 23, 2012 11:56 am
They have come from a registered company got 12000 miles warranty or 12 months whichever comes first. It has to be something befor the injectors as it fluctuates between the two middle injectors if you take electrical connector of to see if there is a difference in running whilst idling. Cheers Richard
Barker1985
Postby Barker1985 » Wed Sep 26, 2012 5:40 pm
Just found out cilinder no has minimal compression problems tried 3 sets of injectors same one all the time. Any body know where I can get new and I mean new engine from? Ivorsearle have on but bit pricey? Cheers Richard
Barker1985
