Change of keys.
Change of keys.
Postby Ga2 » Fri Sep 21, 2012 11:55 pm
Hi
Apologies if this has been discussed before but couldnt find a thread.
I've recently bought an 06 connect.
It came with two keys with separate fobs.
Both of which are pretty knackered. Keys as well as fobs.
Is it possible to use the car style key (with fob built in)?
If so do I have to go to ford?
Can I just get a key cut and then programme the remote?
Any help/ideas much appreciated
Gary.
Ga2
Re: Change of keys.
Postby paul2012 » Sat Sep 22, 2012 12:15 am
Any key from a focus / fiesta/ mondeo & even the transit blue key/remote will work
just need to get new keyblade cut. (just remember to fit the imb transponder in you old key into the new one - although a key cutting place should be able to code key for you)
I,m using a mondeo mk3 flip key for my connect
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Change of keys.
Postby valetech » Sat Sep 22, 2012 8:04 am
If you buy a new all in one key with the transponder already in you can programme it yourself as you have 2 keys already.then program the remote locking yourself aswell
Job done.
molested by:
19s is how we roll
valetech
Re: Change of keys.
Postby Mylee » Sat Sep 22, 2012 1:29 pm
As Vale said, you can do this yourself as you have two keys, search googgle. It's where I got the info to program my all in one key.
Yes a locksmith should be able to program it for you but you're looking upwards of £60. Fords will be double that.
Mylee
Re: Change of keys.
Postby gaz68 » Sat Sep 22, 2012 2:56 pm
i have just the one knackered key with fob,how will i get on ?,can you still get a spare done with just the one key ??
gaz68
Re: Change of keys.
Postby valetech » Sat Sep 22, 2012 4:05 pm
this ONLY works if you have 2 keys,i tried this using 1 key twice and didnt work
1.Insert your first working key
2.Turn to position II and wait 2 seconds
3.Remove the key
4.Insert your second working key
5.Turn to position II and wait 2 seconds
6.Remove the key
7.Now insert the new unprogrammed key
8.Turn to position II and wait 2 seconds
9.Remove new key (New key is now programmed)
10. If you wish to add more keys repeat steps 7 to 9 now
11. To exit programming mode wait 20 seconds
molested by:
19s is how we roll
valetech
Re: Change of keys.
Postby theredcaddy » Sat Sep 22, 2012 6:18 pm
valetech wrote:this ONLY works if you have 2 keys,i tried this using 1 key twice and didnt work
3.Remove the key
6.Remove the key
So does this avoid having to pay a locksmith or Ford the £60-£120 do do the same job, or am I missing something?
Connect T230
theredcaddy
Re: Change of keys.
Postby Altransit » Sat Sep 22, 2012 11:03 pm
theredcaddy wrote:So does this avoid having to pay a locksmith or Ford the £60-£120 do do the same job, or am I missing something?
Yes, so long as you have two fully working keys :)
Re: Change of keys.
Postby theredcaddy » Sun Sep 23, 2012 11:30 am
WooHoo!
I have got two keys!
Perhaps I'll go ahead and buy an all-in-one key!
Thanks for the info guys! :wink:
Connect T230
theredcaddy
Re: Change of keys.
Postby Ga2 » Sun Sep 23, 2012 11:56 am
Cheers gents!
Next question is how much should I expect to pay to get a blank cut.
I assume this would be ok as a blank.
FORD 3 BUTTON REMOTE KEY FOCUS MONDEO TRANSIT CONNECT FIESTA: http://bit.ly/TkVwnd #ebaymobile
Ga2
Re: Change of keys.
Postby gaz68 » Sun Sep 23, 2012 1:07 pm
any of you boys out there know what i do with just one key,it works fine ,so does the fob but i am worried about losing this one key :cry:
gaz68
Re: Change of keys.
Postby valetech » Sun Sep 23, 2012 5:12 pm
dont forget to program the remote locking after
Place your key in the ignition
Turn the key from position 0 to position 2
Do this 8 times in quick succession
Now press any button, the doors will lock and
unlock to signify the remote has been
programmed, to program extra remotes press
any button on each additional remote.
To exit programming mode either turn the
ignition on and off or simply wait 20 seconds
gaz68 wrote:any of you boys out there know what i do with just one key,it works fine ,so does the fob but i am worried about losing this one key :cry:
if you have only one key.you cant program the transponder yourself and will need to call a auto locksmith
molested by:
19s is how we roll
valetech
Re: Change of keys.
Postby gaz68 » Sun Sep 23, 2012 5:32 pm
i wonder how a locksmith does it ? ,some lads on here must know :wink: :wink:
gaz68
Re: Change of keys.
Postby Altransit » Sun Sep 23, 2012 5:51 pm
gaz68 wrote:i wonder how a locksmith does it ? ,some lads on here must know :wink: :wink:
Knowing how to do it, and having the expensive equipment to do it, aren't the same thing though :)
Re: Change of keys.
Postby lg5489 » Thu Oct 18, 2012 6:16 pm
Hi, just a quick question regarding this. Im just about to buy a 3 button remote key. I have a 2001 transit with 2 working keys and one seperate remote. Will any 3 button remote work i.e from focus, mondeo, fiesta? becasue ive read about different types of chips in the keys not working with certain ages of transit.
thanks for your help.
Lewis.
lg5489
