Transit connect 2004 tddi lack of power
Re: Transit connect 2004 tddi lack of power
Postby Marty.H » Mon Nov 05, 2012 8:21 pm
Little bit of an update:
Gave the van a service all the filters and its going a lot better the air filter was that bad the van had tried to suck it in :shock:
I have also added injector cleaner into the fuel to see how that goes next is to clean out the inlet manifold and map sensor and cap the EGR system
ill keep you posted :mrgreen:
Marty.H
Postby liteace » Tue Nov 06, 2012 12:34 pm
Marty.H wrote:Little bit of an update:
Could have been worse if it had been sucked into to the intake, that would have caused a bit if damage to the turbo, not so bad having a clogged air filter sucked into the van as long as it don't hit you in the eye while driving, nice to know you got it sorted and it was just the basics that were a problem, you've saved some ££££££'s
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
