Original facelift stereo
Postby Elling » Tue May 29, 2012 8:06 am
Does anyone know if the facelift stereo has a line out? I need more sound :roll:
Easier to ask here than to disassemble the dash :)
2010' Transit Connect
2002' Honda CBR F4i
Elling
Re: Original facelift stereo
Postby Elling » Wed Aug 01, 2012 9:38 am
After more research, does anyone know if the radio in the Connect is the same as in S-MAX, Focus and Mondeo ?
Mine has the same shape at least...
http://www.ebay.com/itm/Erisin-ES789F-H ... 19d2d00258
2002' Honda CBR F4i
Elling
Postby westers » Wed Aug 01, 2012 10:49 am
if its a ford CD6000 fitment it will fit :) the standard cd player in most fords is the CD6000
WESTERS T220 LX connect
westers
Postby C8XY » Wed Aug 01, 2012 11:21 am
You can run an amp off of speaker outputs, the sound quality from the ford head units is pretty bad though
C8XY
Postby Elling » Wed Aug 01, 2012 3:17 pm
westers wrote:if its a ford CD6000 fitment it will fit :) the standard cd player in most fords is the CD6000
Thank you, I'm also waiting for an answer from the seller, I'll report here if it's a fit. :)
2002' Honda CBR F4i
Elling
Postby Elling » Wed Aug 01, 2012 3:20 pm
C8XY wrote:You can run an amp off of speaker outputs, the sound quality from the ford head units is pretty bad though
Yeah, that was the last sollution, but I'd rather buy a new player with aux-out, now that I have found it on ebay :)
I have a amp to use on the speaker outputs, but the poor quality you get from this has stopped me from tearing the interiour apart :)
2002' Honda CBR F4i
Elling
Postby Elling » Thu Aug 02, 2012 3:03 pm
Call me a madman, but I bought this one:
http://www.erisin.com/index.php?main_page=product_info&cPath=&products_id=190
The next question is then, has anyone disassembled the dashboard in the new Connect? :roll:
2002' Honda CBR F4i
Elling
Postby paul2012 » Mon Aug 06, 2012 7:43 pm
Yes
Pop Off the top cover complete with the central air vents (11 retainer clips securing the top panel to the dash molding)
Now the Centre panel around the stereo should easily be removed (held in place with four 4 clips)
Hope this helps
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Elling » Tue Aug 07, 2012 8:44 am
Thank you very much, now i have a idea where to start. :)
The cd-player has not arrived yet, but I guess I have to post some pictures here when I'm done :)
2002' Honda CBR F4i
Elling
Postby Elling » Tue Aug 07, 2012 3:36 pm
Also bought these for the doors: Hertz Dieci DSK 130.3
799,- Norwegian Kroner = 85£
http://www.elutstyr.no/product_info.php?products_id=6198
Link to english specs: http://www.elutstyr.no/info/hertz_Dieci_DSK_130_tech.pdf
2002' Honda CBR F4i
Elling
Postby Elling » Tue Aug 07, 2012 3:40 pm
Still have not received trackingnumber from the guys I bought the cd-player from, so I'm glad I used paypal. Then I'll just have to get my money back if they don't start answering my mails soon..... :evil:
2002' Honda CBR F4i
Elling
Postby paul2012 » Sun Aug 12, 2012 9:44 pm
Hi
Did you also order the CAN-BUS adaptor ??
As you will require it, Especially for the GPS. Theres no anologue speed pulse wire on connects from 2006 onwards - So GPS navigation will not work
A CAN-BUS system is a digital communications network where all components are talking to each other. The C/L module, ECU, intrument panel, Airbag, wipers, heater & stereo are all connected to this CAN-BUS system
(Thats why when you adjust the time clock the the instrument panel it also adjusts the time on the stereo automatically, as they are effectively linked together !
On the stereo wiring harness thats plugs into the back of the original stereo, these are the main wiring connections
BATT 12v+
IGNITION SENSE (Ign Live - acc)
ALARM SENSE
ILLUMINATION
GROUND
KEYCODE GROUND
CAN + (CAN-BUS HIGH)
CAN - (CAN-BUS LOW)
RIGHT SPEAKER +
RIGHT SPEAKER -
LEFT SPEAKER +
LEFT SPEAKER -
On a final note members that own connects from 2006 onwards & wish to fit the Sony gen 2 stereo may find the stereo has to be programmed to their vehicle using the CAN-BUS
paul2012
Postby valetech » Sun Aug 12, 2012 9:48 pm
i had this problem when i changed my unit,i just put in a new switched live
molested by:
19s is how we roll
valetech
Postby paul2012 » Sun Aug 12, 2012 10:17 pm
valetech wrote:i had this problem when i changed my unit,i just put in a new switched live
New switched live ? may I ask where is was connected to, at the stereo end ?
paul2012
Postby Elling » Mon Aug 13, 2012 10:15 am
paul2012 wrote:Hi
No, I did not order the can-bus adaptor, then I'll order it stragiht away if you are telling me I am going to need it :)
Thank you very much :)
2002' Honda CBR F4i
Elling
