Racking Installation (with pics - resized)
Postby C8XY » Sat Jun 30, 2012 6:06 pm
Ok trying again with resized pics (800x600)
As the sun finally came out, threw some racking in :D
Frame
Cheeky subwoofer
Ply time
Right tool for the job
All about the scribe!
90% there
Need to see if these work, will ideally connect to interior light circuit and install above each shelf
All thats left is to install some more ply to stop stuff rolling off the shelves and on the right hand side and on the front of the subwoofer enclosure. We ran out and its beer o'clock now so will have to wait until monday!
C8XY
Re: Racking Installation (with pics - resized)
Postby Herts » Sat Jun 30, 2012 7:33 pm
Very Good cutting in.
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby westers » Sat Jun 30, 2012 8:26 pm
looks good mate! i made a cardboard template and a jig saw for my scribeing has to be perfect doesnt it!
rack looks really good! and so do the LED strip lights! thats a really good idea!!
WESTERS T220 LX connect
westers
Postby C8XY » Sat Jun 30, 2012 8:53 pm
Thanks guys, wish I could take credit for the cutting in but it was down to my mate who has a lot of patience and a lot of OCD!!
Hopefully the LED works, its a 12v strip but I've only ever run these in domestic properties off a constant voltage driver. The van voltage may fluctuate too much and pop them, I'm getting the soldering iron out tomorrow so we'll find out :)
EDIT/ going to run them through a voltage regulator, will update with pics when I'm done.
C8XY
Postby Adam_84 » Sat Jun 30, 2012 11:51 pm
Looking good, look forward to seeing the led lights working
Adam_84
Postby C8XY » Wed Jul 04, 2012 6:47 pm
I had some time spare today so I dusted off my soldering iron and went to work...
I made up the 12v regulators, tested them against the supply of 12.8v and the output was 12v. Turned engine on and input was around 14v but the output was 12.5v so all seemed well.
However once the LED load was connected, the output dropped to below 1v so I presume the load exceeded the rating of these regulators and it shut off the power.
I ended up ditching the regulators and connected direct to existing wiring. They run fine at up to 14v luckily.
In position:
Not visible when off, and will not get damaged when removing items from shelves:
This is what they look like from underneath:
And this is the outcome, well lit shelving - I'm very happy with it.
C8XY
Postby C8XY » Wed Jul 04, 2012 6:49 pm
Now I need to wire up those amps and finish the ply so everything stays on the shelves!
C8XY
Postby Adam_84 » Wed Jul 04, 2012 9:05 pm
That looks good, so you just wired them into the interior light harness?
Adam_84
Postby C8XY » Wed Jul 04, 2012 11:28 pm
Yes mate, removed the centre light and pulled the wiring out, they come on when you open the door as normal. :)
C8XY
Postby Adam_84 » Thu Jul 05, 2012 9:02 am
How many strips of those LEDs do you think could be run from that harness? And do you have link for where you got them from please
Adam_84
Postby C8XY » Thu Jul 05, 2012 12:48 pm
The spec of this particular strip is 4.8W/mtr @ 12v.
I removed the original centre light which freed up about 20W I believe.
Technically you should be able to run about 4 meters of it without exceeding the original lamps.
Not sure where it came from, was an "off cut" from site ;)
C8XY
Postby Adam_84 » Thu Jul 05, 2012 7:02 pm
Ok nice one cheers for the info mate
Adam_84
Postby kjb » Thu Jul 05, 2012 7:07 pm
What did this cost you ,with the exception of the lighting?Any thoughts of manufacturing a few & selling via egay?
kjb
Postby Adam_84 » Thu Jul 05, 2012 9:33 pm
Do these look like the same as you have?
http://item.mobileweb.ebay.com/viewitem ... 1034886382
Guessing it's just - to - and + to +
Adam_84
Postby Mylee » Fri Jul 06, 2012 11:30 am
I have used these guys for all sorts, lights in my van, garden and kitchen. Great service.
http://www.litewave.co.uk/
Mylee
