anyway ive bought F Super off ebay and connected the van up to the laptop and read the codes. now im getting:
P1342 Pedal demand seosor
P1631 Main Relay
B1681 PATS Transeiver module signal is not received.
The van still starts if i use easy start but cuts off after bout 10 seconds then the ignition light flashes. Ive had all the injector codes re programmed but for some reason its gone back to how it was now, ill attach a pic showing the codes. Ill also attach the Live data with the ignition on and when cranking over.
