refused MOT test, how bad? URGENT!
Postby inzor » Fri Oct 12, 2012 10:04 pm
had the van in for an MOT today. according to my brother they have refused to test it as the exhaust is blowing, lights are out and the sills need replaced.
anyone know how much it would cost to put these right? its the sills im worried about.
cheers
inzor
Re: refused MOT test, how bad? URGENT!
Postby lightning » Fri Oct 12, 2012 10:26 pm
Sills gone on a Transit Connect? Has it been washed with sea water every week?
How long is a piece of string....depends how much welding is needed! Did you not check the lights before you took it in?
lightning
Postby TIMO » Fri Oct 12, 2012 10:27 pm
Never heard of a refusal :? surely they have to test it so that you know what to put right ? :roll:
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby duvet » Fri Oct 12, 2012 10:45 pm
mate of mine had a refusal -- then again it had a floor like the flintstones car.
ex-network rail 2007 mk7 100 LWB 350 8 seat.
buses stop at bus stations, trains stop at train stations....... on my desk i've got a workstation
duvet
Postby inzor » Fri Oct 12, 2012 10:52 pm
there is a little rust on jacking points but nowere else.
lights have new bulbs, all working fine. must need them aligned.
i knew there was a hole in the flexy pipe on the exhuast after the downpipe but didnt have time to fix it.
refused as the work couldnt be done within the free re-test time or something?
all this is from a text from my brother, who works there, he cant remember what other fualts there might be.
i honestly expected to only fail on the blowing downpipe flexy, it drives perfectly, lights give plenty of...light, good on fuel, no loss in power, litrally everything works. and it doesnt pull to the side under braking or anything, also handles well and no knocking anywere.
spoze i could youtube how to adjust the lights, get it up on a ramp and see what my uncle thinks when he's back on shore. hes a welder/blacksmith.
inzor
Postby FredTransit » Fri Oct 12, 2012 10:57 pm
if they havent put it on the system, take it somewhere else. The excuse they gave sounds like bullsh*t to me......
FredTransit
Mk2 Trannyist
Postby TIMO » Fri Oct 12, 2012 10:59 pm
FredTransit wrote:if they havent put it on the system, take it somewhere else. The excuse they gave sounds like bullsh*t to me......
Me too :? even if you cant get it done in the free retest threshold,,, theyre just supposed to charge you again .
TIMO
Postby matthew2riches » Fri Oct 12, 2012 11:03 pm
I've had a car refused before. If they could condemn it they would of :oops:
matthew2riches
Postby paul2012 » Sat Oct 13, 2012 2:47 am
An MOT refusal mean it's been through a MOT test but has failed ! :roll:
VOSA'S Rules reguarding MOT retests
If the vehicle is left at the testing station for repair and is retested before the end of 10
working days following the day of the initial failure, then only a partial retest is needed
for which no fee may be charged.
If the vehicle is removed from the testing station for repair and returned for retest within
10 working days following the day of the initial failure, then only a partial retest is
needed and a partial retest fee may be charged
Basically, the garage have 10 days in which do the work & retest it for fee.
If you take the van away from the garage, you have up to 10 days in which to re-submit for MOT retest & they should only charge you a partial MOT test Fee !
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby get connected » Sat Oct 13, 2012 5:30 am
If they didn't charge you it sounds as though they've done you a favour by making you aware that it needs some bits n bobs doing first....
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Postby lightning » Sat Oct 13, 2012 10:26 am
Oh right, just alignment! When you said "lights are out" thought you meant out as in not lit up!
Jacking points corroded well I guess the van could be ten years old now, so it's possible. Take it somewhere else for a second opinion would be my advice.
lightning
Postby FredTransit » Sat Oct 13, 2012 11:23 am
paul2012 wrote:An MOT refusal mean it's been through a MOT test but has failed ! :roll:
thats not the way l read it, l get the idea the van wasn't tested at all. Maybe l got the wrong end of the stick? A refusal of an MOT certificate is a fail.
FredTransit
Mk2 Trannyist
Postby blue estate » Sat Oct 13, 2012 11:52 am
Same as if mot tester refuses to do smoke test instant fail :wink:
blue estate
Postby FredTransit » Sat Oct 13, 2012 12:51 pm
but which is it in this case? Accormding to the thread title the test itself was refused. I would think that would mean it wasn't even entered on the system, though could be wrong. Maybe the OP can clarify?
FredTransit
Mk2 Trannyist
Postby kjb » Sat Oct 13, 2012 1:39 pm
Right as a tester myself,you can refuse to test a vehicle,if the vehicle is not fit to be driven,levels low,excess smoke,doors bonnet ect won't open,if whilst conducting the test you find an item which falls into a category of dangerous you can abort the test or abandaon,but you will be issued with a v30 listing the reason why,a blowing exhaust is not a refusal,you cannot refuse to carry out an emissions test if all pre checks are satisfactory.All pre checks should be undertaken before logging the test onto the vosa linked pc
kjb
