how long for heater to get warm
Postby kjb » Thu Dec 13, 2012 9:53 pm
Is my connect any different to any other I ask,during summer the temp gauge runs approx half way & the heater will burn your eye balls out,come winter the gauge struggles to move & even after 20 miles or so the heater is only luke warm,I was thinking of renewing the thermostat,but don't want to mess in sub zero temperatures if this is normal
kjb
Re: how long for heater to get warm
Postby blue estate » Thu Dec 13, 2012 9:58 pm
No it's not normal on a 20 mile trip change the thermostat
blue estate
Postby l33uum » Thu Dec 13, 2012 10:00 pm
As above not normal, should get warm after 2-3 mile.
l33uum
Postby gt_addict » Thu Dec 13, 2012 10:52 pm
I've found it all depends on how I drive it. If I'm constantly putting the turbo under load it wil warm up within 5-7miles. If I'm being a Sunday driver and light on the throttle mine can take around 15miles to warm up. I don't touch te heater until its sitting in the middle as if I hit traffic and have te heater on the gauge will drop pretty fast.
gt_addict
Postby mrtn » Fri Dec 14, 2012 6:56 am
I suppose you don't have the aux heater installed? That's exactly what it did when I had mine broken.
1.6 Ecoboost A/T LWB '16
mrtn
Postby liteace » Fri Dec 14, 2012 9:18 am
I put a brand new genuine Ford stat in this week & its no better, sometime where I have to work is very high up, even if I start the engine 5 mins before I leave when Im driving the 4-5 miles back down to the main road it just stays on cold, I know the engine is no going to produce much heat when is not under load but they could have designed the cooling system a little better
liteace
Postby gt_addict » Fri Dec 14, 2012 9:34 am
mrtn wrote:I suppose you don't have the aux heater installed? That's exactly what it did when I had mine broken.
Nope I haven't got the aux heater. I asked about the factory fitted one in another thread but it seemed a bit long winded to fit. I'm toying with the idea of covering the front of the radiator like they do on old land rovers and the lorries that drive in the arctic. Just got to figure out what to cover it with and how to fasten it.
gt_addict
Postby Adam_84 » Fri Dec 14, 2012 1:20 pm
Would strong magnets and a semi breathable fabric do the trick to cover up part of the rad? Mine takes a while to warm too but I did find that having it on the hottest setting seemed to get the warm then hot air coming through quicker.
Adam_84
Postby gt_addict » Fri Dec 14, 2012 2:21 pm
That's an ingenious idea. Just wonder how te magnets would hold up with te constant bumps and jolts of driving though.
I have been looking at kenlowe preheaters but they seem a tad expensive really.
gt_addict
Postby liteace » Fri Dec 14, 2012 4:12 pm
Adam_84 wrote:Would strong magnets and a semi breathable fabric do the trick to cover up part of the rad? Mine takes a while to warm too but I did find that having it on the hottest setting seemed to get the warm then hot air coming through quicker.
It would slow down the air flow through the rad but that could cause a problem when the engine is under load and needs cooling + it would not warm up any quicker
as there is no warm \ hot coolent in the rad when the thermostat is closed, all its doing is circulating around the engine and the heater
liteace
Postby winterheating » Fri Dec 14, 2012 5:09 pm
Exactly, totally pointless and the rads are uluminium.
winterheating
Aluminium
winterheating
Postby g-man » Fri Dec 14, 2012 5:48 pm
used to put a hessian sack over it........mine seems to warm up ok cause its got the aircon dad and i/cooler in front
g-man
Postby blue estate » Fri Dec 14, 2012 5:54 pm
Whats a air con dad :?: :lol: :lol:
blue estate
Postby g-man » Fri Dec 14, 2012 6:02 pm
oops :lol:
g-man
