90ps connect vs 90ps focus, what happened??
Postby Bailey. » Sun May 12, 2013 12:06 am
I drove a friends loan car at his garage shoot out to get some milk the other day and was shocked how much better it went than my 90ps tdci connect, wen I got back and mentioned it he said it was a tddi so not exactly like mine but it felt a lot quicker, not a little. So I'm thinking the only thing that can really have an effect is the box ratio, if so, where do I sign?? And would it be interchangeable with my 2008 90ps connect?
Bailey.
Re: 90ps connect vs 90ps focus, what happened??
Postby gt_addict » Sun May 12, 2013 12:41 am
Get a focus box with the speedo sensor in the right place and change it over basically. It will be crap for pulling weight though.
gt_addict
Postby Bailey. » Sun May 12, 2013 8:38 am
Thanks;) so ref clutch and flywheel it will all be the same? Has anyone done it on here?
The max weight I pull is around 200kg so not an awful lot on that front!
Bailey.
Postby gt_addict » Sun May 12, 2013 9:46 am
As far as I know it's the same box so the same clutch and flywheel. If you're that worried see if you can use a website to check the part numbers from each vehicle and see if they match.
gt_addict
Postby liteace » Sun May 12, 2013 10:53 am
Focus final drive ratio 3.41
Connect final drive ratio 4.06
both are fitted with MTX75 g\box, you can see the difference here between the 4.06 & 3.41
liteace
Postby Bailey. » Sun May 12, 2013 12:51 pm
I can't quite get my head around it ATM! The gears will be longer by quite a bit, so will my connect perform EXACTLY like the 90ps focus(longer gears as such) I just. Ant imagine the connect driving like the focus???
Bailey.
Postby LeeH » Sun May 12, 2013 1:44 pm
I guess you will loose torque but if you are not pulling then its no problem. Maybe with a remap/chip box whatever, you would replace that lost torque.
Mine is a very eco van if you keep it off the motorway so I'm hoping to swap out my box when the clutch goes for the focus box.
LeeH
Postby paul2012 » Sun May 12, 2013 6:15 pm
The connect sportvans Ratio is 3.80
connects 110ps from 2009 onwards the Ratio is: 3.80
So fitting a focus TDCI mk1 115ps gearbox (3.41)
or TDDI 90ps (3.41)
will be fine, just a slight reduction in torq but they will fit no problem. :wink:
Just remember to fit your original gear selector mech to the top of focus gearbox, otherwise you will fine the gears are upside down :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby g-man » Sun May 12, 2013 7:14 pm
paul2012 wrote:The connect sportvans Ratio is 3.80
all 110's are 3.80
g-man
Postby Bailey. » Sun May 12, 2013 7:26 pm
So a 3.41 ratio box, along with a van tuner remap should make a big performance increase and in someways just a nicer van to drive? And shouldn't make any difference on fuel economy?!
Bailey.
Postby LeeH » Sun May 12, 2013 7:30 pm
Bailey. wrote:So a 3.41 ratio box, along with a van tuner remap should make a big performance increase and in someways just a nicer van to drive? And shouldn't make any difference on fuel economy?!
Mpg should have a noticeable increase I would have thought.
LeeH
Postby Bailey. » Sun May 12, 2013 7:40 pm
I still have to ask, why has nobody done this gearbox change? seems a little to good to be true in someways as these boxes are as little as £50 on eBay!
Bailey.
Postby LeeH » Sun May 12, 2013 7:43 pm
I'll be doing mine, hopefully Paul will suss out a 6 speed option.
LeeH
Postby gt_addict » Sun May 12, 2013 9:21 pm
I haven't done it as I'm always carrying some weight and plan to fit a towbar for versatility so would need the shorter ratios. It just boils down to whether you use your van for work or social really.
gt_addict
Postby Bailey. » Sun May 12, 2013 10:30 pm
I use mine for work but tools consist of a hand held box, multi meter and a battery drill. Plus a 8-10 boxes of spares weighing no more than 150kg, so really the max I will ever carry is 200kg. I dont think it will have any effect on me, looking into it even more I suppose you could compare weights of the focus and connect to get a better idea.
Bailey.
