Connect 1.8 TDCI
Connect 1.8 TDCI
Postby ishmail » Tue Jun 25, 2013 8:50 pm
hi there i have a ford connect year 06 so many problems with this van but maybe related to one thing not sure any ways everyday i have to fill the van up with water with 2 Lt bottle when i go somewhere like drive the van for 2 hours water tank is empty the is no leak anywhere that i can see i check the pipes under the engine back of the engine nothing when i start the engine white smoke coming out with bad smell and some oil at the back of the exhaust thanks in advance
ishmail
Re: Connect 1.8 TDCI
Postby paul2012 » Tue Jun 25, 2013 9:02 pm
welcome to the forum :D
Sounds like head gasket :!:
Engine overheating ?
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby g-man » Tue Jun 25, 2013 9:04 pm
welcome m8y :) .......could be egr cooler,bridge the pipes and see if that sorts it
g-man
Postby ishmail » Tue Jun 25, 2013 9:49 pm
hi thanks for having me here the engine don't over heat at all
egr cooler,bridge the pipes is that something i can do or it has to be mechanics job :?:
ishmail
Postby g-man » Tue Jun 25, 2013 9:59 pm
depends on you mate.....awkward to get at tho'
g-man
Postby ishmail » Tue Jun 25, 2013 10:06 pm
ok ones i get to ti take it out and clean it or get a new one and replace it im a plumber lol awkward dont mean anything i can try if i know what to do :D
ishmail
Postby Altransit » Tue Jun 25, 2013 11:23 pm
:idea: If you're a plumber, then connecting two water pipes together, in an awkward place, should be right up your street :P :lol:
Postby ishmail » Wed Jun 26, 2013 10:20 am
ok im gona try that today one more thing i found out that my heater not working blowing out cold air :oops:
ishmail
Postby ishmail » Wed Jun 26, 2013 11:46 am
i had a look and there is some water in there and oil is that normal
ishmail
Postby gt_addict » Wed Jun 26, 2013 12:34 pm
I'd say that's your egr cooler knackered. Do as mentioned above. That UFO thing you've taken a picture of, underneath that is a small 8 inch long cylinder which is the cooler. It will have two rubber coolant pipes (one at either end) take them off as connect them up and see how your water level is. If it still goes down then its more than likely head gasket, if it stays fills up then you've found your problem and you can either fit a new one or leave the two pipes together and blank the egr off with a plate.
gt_addict
Postby ishmail » Wed Jun 26, 2013 1:38 pm
ok thank you im going to do that and let you guys know what ever the outcome is thank you :)
ishmail
Postby ishmail » Thu Jun 27, 2013 7:19 pm
ok i have connected the two pipes together and fill the cooler drive a round all day with it i didnt loose any water at all my heater works no more bad white smoke at all
so it it safe to leave it both connected like that without buying a new egr or do i really need to get a new egr and fit it on the van and connect them two pipes back on the erg thanks for all you help :D
ishmail
Postby gt_addict » Thu Jun 27, 2013 7:54 pm
Nice to hear its sorted. Have you blanks off the egr valve? eBay do the plates and its just two small bolts under the egr at the end of the ribbed metal hose. One that's done and if the pipes are secure I don't see why you need to worry about another egr cooler imo.
gt_addict
Postby g-man » Thu Jun 27, 2013 8:00 pm
ishmail wrote:ok i have connected the two pipes together and fill the cooler drive a round all day with it i didnt loose any water at all my heater works no more bad white smoke at all
:wink:
g-man
Postby ishmail » Thu Jun 27, 2013 8:06 pm
gt_addict wrote:Nice to hear its sorted. Have you blanks off the egr valve? eBay do the plates and its just two small bolts under the egr at the end of the ribbed metal hose. One that's done and if the pipes are secure I don't see why you need to worry about another egr cooler imo.
no i didn't blank the egr but i already have the black ready to go on there it works without blacking the egr? if i have to do it then i will thanks :D
ishmail
