P0490 egr question
P0490 egr question
Postby onejay » Tue Jun 24, 2014 10:10 pm
had an issue with my connect,its a 2006 tdci with 123000 miles
reader brought up a code for the maf sensor which was very dirty,cleaned it refitted and cleared the code
at the same time i fitted the egr blanking plate but today on my way home the engine management light was on
scanned it and it comes up with P0490 code and the van is still lumpy and kind of dies on you about 2k same as before
have i done anything wrong,have i fitted the egr plate in the correct place ?
onejay
Re: P0490 egr question
Postby liteace » Tue Jun 24, 2014 10:18 pm
Where did you fit it ?
liteace
Postby paul2012 » Tue Jun 24, 2014 10:23 pm
P0490 EXHAUST GAS RECIRCULATION (EGR) "A" CONTROL CIRCUIT HIGH
2006 connect. 75 ps 90ps, TDDI or TDCI ?
2006 is the change over year, has it Euro 3 or Euro 4 engine ?
(Euro 4 has a electronic EGR valve)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby onejay » Tue Jun 24, 2014 10:23 pm
at the top part of the pipe near the top of the engine
onejay
Postby onejay » Tue Jun 24, 2014 10:25 pm
75 tdci
onejay
Postby onejay » Tue Jun 24, 2014 10:26 pm
how do i tell the difference from the 3 or 4
onejay
Postby liteace » Tue Jun 24, 2014 10:27 pm
onejay wrote:at the top part of the pipe near the top of the engine
Does it have round EGR vac controlled or squarish EGR electronic controlled ?
75ps TDCI will be Euro 4
you need to check EGR control motor
liteace
Postby paul2012 » Tue Jun 24, 2014 10:28 pm
onejay wrote:how do i tell the difference from the 3 or 4
75ps TDCI will be a Euro 4 engine.
Fitting a EGR blanking plate will not solve the problem :(
paul2012
Postby onejay » Tue Jun 24, 2014 10:36 pm
onejay
Postby onejay » Tue Jun 24, 2014 10:37 pm
what needs to be done Paul
onejay
Postby liteace » Tue Jun 24, 2014 10:38 pm
Did you fit blanking plate with small hole in the middle or the other type that is complete blank ???
liteace
Postby onejay » Tue Jun 24, 2014 10:40 pm
blank
onejay
Postby liteace » Tue Jun 24, 2014 10:41 pm
wrong one, you need one like in photo
liteace
Postby onejay » Tue Jun 24, 2014 10:41 pm
ah
can i just drill a hole in the one i fitted
onejay
Postby liteace » Tue Jun 24, 2014 10:42 pm
onejay wrote:ah
Yep, it cant make it any worse, just make sure you wash \ clean all the metal swarf off, you dont need that being sucked into the engine
liteace
Users browsing this forum: Baidu [Spider]
