Quick clear screen and sat nav reception?
Postby M4carp » Tue Dec 02, 2008 9:38 am
Does the quick clear heated screen interfere with sat nav reception, on my old mk6 transit I had to fit an external aerial for my Garmin to work properly and that had a heated screen.
08 230LX 110ps 18" st alloys Pioneer HD3BT Hertz amps/speakers Toad AI606
M4carp
Re: Quick clear screen and sat nav reception?
Postby tottespurs » Tue Dec 02, 2008 10:06 am
yes it will blocks out the satalites
tottespurs
Postby M4carp » Tue Dec 02, 2008 3:03 pm
Thought so, aerial on the roof then :x
M4carp
Postby tottespurs » Tue Dec 02, 2008 3:31 pm
yep
tottespurs
Postby Lefty64 » Tue Dec 02, 2008 3:56 pm
M4Carp,
The info. on here is sometimes worse than the spelling. The heated screen element on the Connect doesn't block the GPS satellite signal. The clue might be in that your man says it 'will' do this, but I'm guessing that once he actually tries this he'll find he's wrong.What I'm not guessing at is my navigating thousand of miles with my own satnav which has worked faultlessly.
There might be a problem with certain brands of kit as the GPS signal is weak. It needs a quality receiver. Suggest you buy a TomTom. You won't need an external aerial I promise you.
Lefty64
Postby M4carp » Tue Dec 02, 2008 5:07 pm
I will post up the results when I get around to fitting a pioneer system with built it sat nav, hope it works without the external aerial.
I just tried a garmin street pilot 2620 and the windscreen did block loads of signal but that unit is about 6 years old now.
M4carp
Postby belly » Tue Dec 02, 2008 6:03 pm
i dont think its quick clear screens! well my tom tom works fine on mine :D did your old transit have air con? im not sure about this :? but my old car was air con and had a heat reflective screen for the summer i guess! that effects sat nav :)
belly
Kaiser Chief
Postby Lefty64 » Tue Dec 02, 2008 10:20 pm
Do you mean the air conditioning system installed in PSA vans & cars, such as Peugeot & Citroen? These have the option of AirCon combined with an athermic windscreen to reflect the sun's rays back off the surface of the glass, so it doesn't enter the cabin.
As these probably have metal particles embedded in the windscreen (?) there might be be problems with Satnav reception.
Lefty64
Postby sport110 » Tue Dec 02, 2008 10:25 pm
TomTom works fine :D :D
Ford Transit Connect Sport 110
sport110
Postby belly » Tue Dec 02, 2008 10:34 pm
thats the word athermic :lol: i know it cost more on the options list :roll: not just froggy though :D
belly
Kaiser Chief
Postby WINDSCREENGUY » Tue Dec 02, 2008 11:40 pm
heated screens dont effect sat navs but solar coated screens do
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby M4carp » Tue Dec 02, 2008 11:50 pm
My old mk6 wasn't solar coated but was heated and it definately effected the reception, under screen signal low - hang it out window signal high so I had to fit an external aerial and does the same thing in the connect, maybe its just the Garmin streetpilot that does it?
M4carp
Postby jolly olly » Wed Dec 03, 2008 12:02 am
Tom Tom works in my mates jumbo and the wifes Fusion both have a heated screen.
Life is not a dress rehearsal
jolly olly
Postby Mike » Wed Dec 03, 2008 12:09 am
IME the athermic screens and heated screens will reduce the signal that's available to a sat nav. The early Tom Tom Go300 etc was awful in my Transit with a heated screen and wouldn't work at all in our car which had an athermic screen, thankfully I bought a Go510 which worked a treat. So the good news is that any sat nav with a SiRF Star III chip or later will have no issues.
Mike
Wind up merchant!
Postby WINDSCREENGUY » Thu Dec 04, 2008 7:30 pm
my vans windscreen is heated as is my car and i use my tomtom 720 no problems :shock:
WINDSCREENGUY
