Rear Disc Brake Pad Change on a 2006 Transit Connect
Postby BrownKnows » Mon May 23, 2011 5:35 pm
Hi, My connect failed its MOT, and I'm doing the jobs myself. I've just changed the front pads easily enough, but before I start the rear pads replacement. I thought I would check to see, if there was anything different on the rears. i.e. will I need to use any special tools to push the brake cylinders back - I used a G clamp on the fronts. Also, how difficult is it to adjust the hand brake? Thank you!
BrownKnows
Re: Rear Disc Brake Pad Change on a 2006 Transit Connect
Postby electric » Mon May 23, 2011 9:06 pm
Probably need a caliper wind back tool to screw the piston back into the caliper, shouldn't need to adjust the handbrake once the new pads are fitted. :)
2005 T220 LX TDCi Rolling on 18 inch Jaguar alloys
http://www.acornautoservices.co.uk
Servicing and Repairs, MOT testing, A/C systems regassed
electric
Postby blue estate » Mon May 23, 2011 9:07 pm
electric wrote:Probably need a caliper wind back tool to screw the piston back into the caliper, shouldn't need to adjust the handbrake once the new pads are fitted. :)
yep if the brakes are the same as the focus then you do need wind back tools :wink:
blue estate
Postby BrownKnows » Tue May 24, 2011 9:24 am
Thanks for the help and replies.
BrownKnows
Postby BLUECONNECTION » Tue May 24, 2011 10:05 am
you might be able to do it with a pair of long nose pliers, open them up and put each side of the prongs on opposite sides of the piston (you'll see grooves on the piston to locate it on the brake pad so put the prongs in these grooves) then using the pliers rotate the piston clockwise while pushing firmly
BLUECONNECTION
Postby BrownKnows » Wed May 25, 2011 2:22 pm
Thank you Blue Connection. Using long nose pliers did cross my mind, but I am fortunate enough to have my own hand tool business, so I've purchased a Draper ABS brake tool, which looks like it will do the job. Should arrive in the morning, so I will give that a go. Thanks again.
BrownKnows
Postby Piglet » Sat Jan 24, 2015 8:28 pm
I'm recycling this old thread just to prove I searched before posting :wink:
That said, I don't understand. Why won't my rear caliper pistons wind back with a clamp, they won't, I've tried.
The pistons advance when the handbrake lever is pumped and stay out.
Also, it looks like I've got seized handbrake cables, how do you release the front end with the exhaust & heat shield in place?
Piglet
Postby paul2012 » Sat Jan 24, 2015 10:37 pm
Piglet wrote:I'm recycling this old thread just to prove I searched before posting :wink:
You have to rotate piston in the caliper while pushing it back at the same time. Hence the use of a wind back tool.
One here will do the job.
http://www.ebay.co.uk/itm/21PC-Brand-Ne ... 2c8ffadbae
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Piglet » Sun Jan 25, 2015 9:26 pm
Thanks Paul, not entirely sure how that works but kit is ordered.
While you're here,
Can you tell me how to get the handbrake cables out?
Piglet
Postby paul2012 » Sun Jan 25, 2015 9:43 pm
Piglet wrote:Thanks Paul, not entirely sure how that works but kit is ordered.
While you're here,
You don't nee to take handbrake cable off to replace pads - Just loosen it of at the handbrake lever :wink:
paul2012
Postby Piglet » Sun Jan 25, 2015 9:48 pm
No, but I do if they are both seized solid, one won't even come back enough to unhook from the caliper.
The cables disappear behind the exhaust heatshield.
Please don't tell me it's exhaust & heatshield off :x
Piglet
Postby paul2012 » Sun Jan 25, 2015 10:15 pm
Piglet wrote:No, but I do if they are both seized solid, one won't even come back enough to unhook from the caliper.
It will give enough slack to remove cable from caliper.
paul2012
Postby Piglet » Sun Jan 25, 2015 10:27 pm
Take the top trim off from inside the cabin?
Is that a centre consule out job?
Piglet
Postby liteace » Sun Jan 25, 2015 10:29 pm
No you dont have to take the centre console out
Just pull up the hand brake gaiter and under the handbrake it the cable adjuster
liteace
Postby Piglet » Sun Jan 25, 2015 10:42 pm
Thanks Paul & Liteace.
Is it possible to draw out and refit new cables once released from inside the cab?
Piglet
