NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby ginsters » Fri Jun 21, 2013 8:36 pm
paul2012 wrote:
ginsters wrote:just read all this thread Paul your nuts!i don't mean that in a negative or nasty way but you might want to phone the mind helpline!
Possibly abit eccentric :lol: :lol: :lol:
Probably gone overboard on this project. But then, do like a good challenge :wink:
Currently deciding on what to do with engine ?
Thinking of changing it for the 1.8 TDCI 125ps engine (QYBA) from a Mondeo mk4 along with the 6sp gearbox 8)
Which should return better MPG & no need to worry on power to weight ratio.
Mondeo mk4's gross weight is heavier than my T200 connect :wink:
thats the motor im looking for to go in the red van
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
Postby paul2012 » Sat Jun 22, 2013 2:18 pm
You still looking for an engine for your connect ?
I will have a TDCI with engine loom & ECU available shortly :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby connect56 » Thu Jun 27, 2013 1:46 pm
Wow, just read all this, im a fully qualified mechanic and I would never attempt this. Hat off to you some incredible work. You say things are straight forward but you obviously know what youre doing. Suppose everythings easy when you know how!
connect56
Postby paul2012 » Wed Jul 03, 2013 2:22 pm
I am going to fit a Mondeo mk4 QYBA engine with 6 speed gearbox.
But to do that I have to change the entire wiring loom front front to back. Current engine is euro 3 & QYBA is euro 4
paul2012
Postby paul2012 » Wed Jul 03, 2013 2:26 pm
Well I picked up a bargain again from ebay
complete bulkhead for £40 :D
Have not bolted it in fully, there's no point when wiring is going to be replaced.
paul2012
Postby paul2012 » Wed Jul 03, 2013 2:36 pm
Obtained the complete wiring looms from a 2007 connect Lx SWB
Well pleased as wiring is equipped for heated front windscreen, ABS & Aircon
Engine bay loom
Dash loom (which I will have to modify & patch in the loom I made up for the 2010 instrument cluster & GEM module etc)
& body loom which runs from front to back
paul2012
Postby liteace » Wed Jul 03, 2013 2:47 pm
paul2012 wrote:
2010 connect GEM module fitted behind fuse panel
Here you can still see the 2 plugs for the original central locking interface, which had been removed & it's wiring connected to GEM module. Also at bottom of pic is the rear door unlock relay :wink:
Why did you buy all that, Im sure you could have made one, did this mess that you made with your added MS-HS CAN that you kept on & on & on about not work then, that was a waste of time
liteace
Postby paul2012 » Wed Jul 03, 2013 3:14 pm
If you read this thread properly, MAIN reason for changing the complete wiring loom. Is so I can fit the mondeo mk4 QYBA 125ps euro 4 engine
My current engine F9DA is euro 3 (Wiring looms are completely different between euro 3 & euro 4 !)
Looms I have just obtained is for a euro 4 engine :wink:
For your info the MS-CAN & HS-CAN networks I added are working perfectly (read previous posts !)
& see vid here :arrow: http://www.youtube.com/watch?v=c--cRAGk10g
& what mess :lol:
On earlier connects the CTM is still built into the Instrument cluster on models from 2006-2009. On models from 2009 onwards it was replaced with GEM module.
So I still have to add in a sub loom for the 2010 instrument cluster, GEM module, steering angle sensor, Yaw rate sensor (ESP), Airbag module & Ambient Air temp sensor !
GEM Module controls indicators / hazards, Air recirculation, wipers, heated mirrors & front screen, headlights, interior lights, central locking & Aircon etc
paul2012
Postby valetech » Wed Jul 03, 2013 3:55 pm
I think liteace is trying to say is.why go to so much trouble and time fitting that lot in to the van to then pull it all out and start again
But i my be wrong
molested by:
19s is how we roll
valetech
Postby paul2012 » Wed Jul 03, 2013 4:51 pm
valetech wrote:I think liteace is trying to say is.why go to so much trouble and time fitting that lot in to the van to then pull it all out and start again.
But i my be wrong
I agree "why go to so much trouble and time fitting" . I would have left it if keeping the engine, unfortunately the current looms are incompatible with new engine
Call it a trial run, just to see if it could be done.
Now I can improve on it by incorperating the sub loom for the 2010 kit into the main replacement dash loom, this way there will only be 1 loom behind the dash instead of 2 :wink:
Replacement 2007 dash loom will not plug straight into the 2004 body loom - different plugs & wiring. Hence why that too has to be changed.
I did plan on retrofitting a heated front windscreen & ABS. I was lucky to get a complete loom with wiring for these alreaady there, which has saved some time. :D
paul2012
Postby paul2012 » Wed Jul 03, 2013 9:22 pm
connect56 wrote:Wow, just read all this, im a fully qualified mechanic and I would never attempt this. Hat off to you some incredible work. You say things are straight forward but you obviously know what youre doing. Suppose everythings easy when you know how!
Thanks 8)
I will be updating this thread in stages as the work progress. Especially when fitting the 6sp gearbox etc :wink:
paul2012
Postby airconman » Thu Jul 04, 2013 10:07 am
Hurry up then and get on with it haha.
But in all seriousness your putting some effort in here mate keep it up.
airconman
Postby ginsters » Thu Jul 04, 2013 10:56 pm
yep it was less hassle to buy another connect whislt i sort that on
the birds love it
53 plate 75ps lwb
ginsters
Postby paul2012 » Fri Jul 05, 2013 3:43 pm
Nice tidy connect you got there :D
Planning on any mods for it, ot just using it until you get your red one sorted ?
paul2012
Postby valetech » Sat Jul 06, 2013 5:52 pm
dont really want to piss on your fire here,but its already been done.i know of a few connects running 6 speed gearboxes even worked on the conversion
molested by:
19s is how we roll
valetech
