What did you do to your connect today?
Re: What did you do to your connect today?
Postby Kent Discos » Wed Aug 15, 2012 1:13 pm
you can't see it.. cleverly angled Paul :wink:
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby Kent Discos » Wed Aug 15, 2012 1:16 pm
Also on Monday... had a centre box fitted and the exhaust put back properly :lol:
Kent Discos
Postby Honey monster » Wed Aug 15, 2012 6:25 pm
:( :( :( Sold her :( :( :(
The only reason she had to go was because of the poor GVTW she had. This one was my first connect but 3rd Transit and I didnt have any problems with either of them. :D :D
Thanks for all the info/advice ive had off you all, And if you think im going to go away just because I am no longer a Transit owner you can think again.This is a really good site and I enjoy reading all the posts. :D :D
Honey monster
Postby blue estate » Wed Aug 15, 2012 6:57 pm
Honey monster wrote::( :( :( Sold her :( :( :(
Like fedup2 you'll be back :wink: :lol: :lol:
blue estate
Postby Drizz » Wed Aug 15, 2012 8:09 pm
I had a result today! All my electric window and mirror kit was plug and play :) Just had to put the three fuses in!
How do the heated mirrors work? are they constant? as the switch doesnt have a heated button like im used to with other vehicles.
One issue i had was the Mondeo handles were completely different and i thought they were the same :(
Also made another template and frame for my centre console. A lot more work needed, and need to make one out of metal:
Drizz
Postby paul2012 » Thu Aug 16, 2012 2:53 am
Drizz wrote:I had a result today! All my electric window and mirror kit was plug and play :) Just had to put the three fuses in!
Thats good to hear your elec window/mirror kit was plug & Play.
Reguarding heated mirrors, they are also connected to the heated rear window relay in fuse panel behind glove box.
As heaters in mirrors turn on when rear window heater/demist is turned on. you will also require the heated rear window switch. (thats according the wiring diagram on the Ford TIS)
Also if you do not have glass in rear doors, the actual wiring for heated rear windows is there, so just a simple matter of adding the relay & switch
The mondeo door handles (complete assembly) will not fit connect, but the handles themselves (not outer casing) will. You need the remove the pin holding the handles in place on the mondeo & connect, and just transfere them accross.
see photoa
I still have a pair of these mondeo crome door handles available if anyone is interested ?
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Thu Aug 16, 2012 3:01 am
g-man wrote:performance blue......best colour imo, whats with the 110 sport badge.......you'll be meat & gravy to the caddy boys :wink:
The VW caddy may have the quicker 140 engines, but the connects can carry more weight than them & still cruise at 80 on the motor way :lol:
paul2012
Postby Drizz » Thu Aug 16, 2012 4:24 am
Cheers Paul. Sounds the same as putting the vectra chrome handles in an Astra. Something I've done a fair bit lol
With those it was obvious how the pin came out but with these mondeo ones it's not. Any pointers?
Drizz
Postby Benwrdn92 » Thu Aug 16, 2012 10:16 am
Cut the bottom of the pin off with a Hacksaw blade. Then take the pin out, insert mondeo handle parts and drop the cut pin back through. Will still be long enough to hold it all together even though the bottoms cut off. Hope that makes sense, if not there's a good guide somewhere on here :D
Benwrdn92
Postby Drizz » Thu Aug 16, 2012 10:20 am
Yeah I googled it earlier and done them all now! One word of warning, be careful with the cable. I accidently bent mine getting the handle off and now had a little kink in it meaning it gets stuck! I've bent it back and lubed it and it's ok at no but I think I'll change the cable to be sure
Drizz
Postby veloce » Thu Aug 16, 2012 1:21 pm
see photoa
Paul,
I will take those Mondeo handles off your hands.
Let me know what cost is and shipping to NI, and then give me a shout.
I have pm'd you my contact details.
thanks
'04 transit connect 75ps
Focus airbox mod
Fiesta Zetec S leather steering wheel
FLI 5.25" speaker upgrade
badge renew
LED sidelights
LED festoons
veloce
Postby Drizz » Thu Aug 16, 2012 2:08 pm
I also have a spare pair so if anyone else wants some after Paul has sold his they're here...
Drizz
Postby Mylee » Thu Aug 16, 2012 8:11 pm
Today, I parked next to another connect :twisted: ..................
Mylee
Postby Drizz » Thu Aug 16, 2012 8:22 pm
Today (amongst other things, see my thread for everything if youre interested) i fitted the 12v in the rear:
Fitted the Mondeo handles:
Rerouted the amp cable through the inner arch instead of the door pillar:
And got the rear axle off:
Drizz
Postby veloce » Thu Aug 16, 2012 8:30 pm
Drizz wrote:Today (amongst other things, see my thread for everything if youre interested) i fitted the 12v in the rear:
a productive day then! :)
Focus airbox mod
badge renew
LED sidelights
LED festoons
veloce
