Drizz wrote: Only issue is the front springs dont compress without load so will fail an MOT....
is this a commen problem with 60mm springs?
Drizz wrote:Although mine wasnt Fords, the sensors fit the connect holders, and are more attractive IMO and was very easy to install, and came with a small screen/display for the sided distance and built in bleeper for less than £50!
Drizz wrote:
This one. The holes are 30mm on the bumper then you have to buy the collars from ford, then these just clipped perfectly into those...
Drizz wrote:Tried the new rears on before blasting and paint:
