What did you do to your connect today?
Re: What did you do to your connect today?
Postby Drizz » Thu Aug 30, 2012 9:45 pm
Oh ok fair do's! I'll stick with mine then!
Drizz
Postby gripper10 » Thu Aug 30, 2012 9:59 pm
done nothing to my '54 lwb.,,,,,,,,,,,,,,but,,,,,,
i've been offered some fat wheels. can't convince myself they are gonna fit. (forget partical) reckon they'd look the nuts!
5 x 108 pcd is the bit i'm ok with. 8.5j on 245/45 r19 40 offset.
what d'ya reckon? 19's too much?
grip.
gripper10
Postby SWtechnologies » Thu Aug 30, 2012 10:00 pm
i got round to fitting my foot well lights..... just used some audi style day time running lights off ebay and mounted them under the bottom lip on the dash with a few cable ties. love the look at night just poped out to check!!!
now that its all lit up down there i need to get some new pedals! anyone got pics of theres?
SW technologies
SWtechnologies
Postby SWtechnologies » Thu Aug 30, 2012 10:02 pm
gripper10 wrote:done nothing to my '54 lwb.,,,,,,,,,,,,,,but,,,,,,
grip.
i thort 19" fit but are just not practical.... i have a set of 18"s if you fancy?
SW technologies
SWtechnologies
Postby paul2012 » Fri Aug 31, 2012 5:34 pm
Finally fitted my mk2 grill today, The bonnet catch is fine - But will need to replace the Key Barrel as it is too short !! :(
Just need to sort out the old badge recess on the bonnet :wink:
Also test fitted the brand new rear bumper & end caps, Just waiting for the top trim pad
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby gripper10 » Sat Sep 01, 2012 9:52 am
grip.
i think you're right, i'll give up on the 19's i'm watching a few set on the bat count down. what ya got?
gripper10
Postby westers » Sun Sep 02, 2012 4:13 pm
fitted the focus bottom half air box + hose and a K&N air filter :)
old Vs new
k and nnnnnnn
all fitted :D
also fitted an EGR blank, which was an absolute f***er to do! the bolts where seized, took about 3 hours to get them undun enough to slide the plate in :evil: but hopefuly the 2 together will make a change :)
WESTERS T220 LX connect
westers
Postby Connect-rick » Sun Sep 02, 2012 4:30 pm
Yep, I agree totally on the EGR blank being an absolute fu**er to fit!!
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby Graham Taylor » Sun Sep 02, 2012 6:31 pm
Connect-rick wrote:Yep, I agree totally on the EGR blank being an absolute fu**er to fit!!
My blanking plate is still in the packet as s**t scared to put anymore pressure trying to undo the bolts!! :(
Graham Taylor
Postby blue estate » Sun Sep 02, 2012 6:33 pm
They're fooooooooooookkkkkkkkkkkkiiiiiiiiiiiiinnnnnnnnnngggggggg tight if my old 04 focus was any thing to go by :twisted: :twisted: :twisted:
blue estate
Postby Connect-rick » Sun Sep 02, 2012 6:40 pm
WD40 then some WD40 followed by a little squirt of WD40!
2006 white 75ps
EGR blank
Connect-rick
Postby Graham Taylor » Sun Sep 02, 2012 6:42 pm
blue estate wrote:They're fooooooooooookkkkkkkkkkkkiiiiiiiiiiiiinnnnnnnnnngggggggg tight if my old 04 focus was any thing to go by :twisted: :twisted: :twisted:
Your telling me and awkward to get your hand round the back plus you cant get a socket on the end only small spanner with not much leverage!!!
Graham Taylor
Postby blue estate » Sun Sep 02, 2012 6:48 pm
What socket set size were you using as i manged to get a 1/4 10mm on a 6" braker bar and undid them
blue estate
Postby dieselboy1978 » Sun Sep 02, 2012 7:23 pm
This is an easy job to do.
Bank account emptied by
DELPHI
dieselboy1978
Postby Graham Taylor » Sun Sep 02, 2012 8:23 pm
dieselboy1978 wrote:This is an easy job to do.
On the 05/06 and earlier the EGR is facing towards the rear of the engine bay and so access is harder than later models which has the EGR turned towards the centre of the engine bay making access easier.
blue estate wrote:What socket set size were you using as i manged to get a 1/4 10mm on a 6" braker bar and undid them
Think I have a 1/4 10mm socket but dont have a bar that fits that size. May nip into local tool shop and see if I can pick one up and give it another go!
Graham Taylor
