NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby Big Jake » Sat Jul 06, 2013 7:46 pm
valetech wrote:
paul2012 wrote:
I will be updating this thread in stages as the work progress. Especially when fitting the 6sp gearbox etc :wink:
dont really want to piss on your fire here,but its already been done.i know of a few connects running 6 speed gearboxes even worked on the conversion
?? Don't understand how your pissing on his fire ?? He started the thread and says he's going to update it in stages, never said it was a first as far as I can see.
Great thread by the way, I for one have learnt a lot from this guy, keep at it paul2012 very informative. Thank you.
Mechanic for the 2012 BRISCA F1 World Champion, 2013 British Champion, 2013 Under 25’s Champion and now 2013 World Masters Champion.
Big Jake
Postby Altransit » Sat Jul 06, 2013 8:21 pm
Is there another thread detailing the fitting of a 6 speed gearbox to a Connect :?: :?
Postby paul2012 » Sat Jul 06, 2013 9:35 pm
valetech wrote:dont really want to piss on your fire here,but its already been done.i know of a few connects running 6 speed gearboxes even worked on the conversion
Yes there are a few connects running round with Focus 2.0 VVT engines fitted (ST170) with 6 speed getrag MT285 gearboxes.
In my opinion the MT285 boxes are awfull with their clunky gearchanges etc & coupled up with DMF's
RS conversions are all 5sp - (Focus mk1 RS also uses MTX75 5sp gearboxes with a ratio of 3.56 & bolted to a 2.0 Zetec EFI 200ps engine)
Is there a connect with a 6sp box bolted onto a 1.8 Duratorq (lynx) engine :?: who knows it's a big world out there..
To be honest, I'm not fussed if I'm the first, second or third one to do it.
Your've worked on a conversion, why not enlightened the forum with the precedure for the 6sp gearshift assembly on the 1.8 Duratorq :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Big Jake » Sat Jul 06, 2013 9:53 pm
paul2012 wrote: Your've worked on a conversion, why not enlightened the forum with the precedure for the 6sp gearshift assembly on the 1.8 Duratorq :wink:
Pulls up a chair. :D
Big Jake
Postby gt_addict » Sat Jul 06, 2013 9:56 pm
I've got the popcorn and the mahoooosive cup of coke :lol:
gt_addict
Postby g-man » Sat Jul 06, 2013 10:16 pm
cokes bad for you gt.......last time i snorted some i nearly drowned :lol:
g-man
Postby Altransit » Sat Jul 06, 2013 10:33 pm
g-man wrote:cokes bad for you gt.......last time i snorted some i nearly drowned :lol:
:lol: :lol: :lol:
Postby Rumble bee » Sun Jul 07, 2013 8:56 am
That was coke cola? :wink:
Rumble bee
Postby Altransit » Sun Jul 07, 2013 1:24 pm
Keep up Chris :!: :lol:
Postby Seriously Limited » Sun Jul 07, 2013 2:43 pm
I've run a couple of 5 series BMW's for the last 13 years. I thought some of the parts for them were a bit on the expensive side, but Connect parts are off the scale.
Nearly a couple of quid for a headlining clip, which would be about 40p for the equivalent BMW item.
Maybe this is how Ford sell vehicles at lower prices, knowing that they'll make it up at the servicing and repair stages.
Andy 2012 T230 Limited UK
millertime_1985 wrote:
paul2012 wrote:After searching everywhere for new clips for the forward section of centre floor console.
In the end, I got them from Ford at a cost of £3.50 each :shock:
Ford part No F4493651
These are used to clip lower sides of console to the mounting brackets :wink:
those look like the same clips used to hold the bumper corner caps on... but £3.50 each is taking the p*ss
T230 Limited, Clifford alarm, sat-nav, rear camera, HID headlamps, front park sensors, leisure battery & onboard charger, fused 12V distribution, RCD 240V distribution, diesel heater, carpeted, insulation & trim, LED lighting
Andy W Midlands
Seriously Limited
Postby liteace » Sun Jul 07, 2013 3:32 pm
paul2012 wrote:Started to work on engine today 8)
Replacement inlet manifold fitted no problem
How was you going to control the new electronic EGR with the original Dephi ECU ?
liteace
Postby paul2012 » Sun Jul 07, 2013 5:03 pm
Very easily :wink:
EGR actuator is a basic dc motor which is sprung loaded.
Energise & it rotates one way, with power cut it returns automatically to it original position (open & close)- NOT A STEPPER MOTOR
The EGR position sensor wiring on both euro 3 & 4 are indentical.
Except for the EVR on the euro 3 is negatively operated compared to the EGR actuator which is positively operated.
Unplug the EVR & connect the GN/BK V+ to pin 1 & BK/GN to pin 5 on the EGR assembly.
Should be connected as follows (on 2003-2006 models ONLY - retrofit)
Pin 1 GN/BK V+ ACTUATOR
Pin 2 YE/GN POSITION
Pin 4 WH/GN POSITION
Pin 5 BK/GN ACTUATOR
Pin 6 BN/GN POSITION
Euro 4 EGR wiring diagram 2006 to present
Euro 3 EGR wiring diagram 2003-2006
paul2012
Postby paul2012 » Sun Jul 07, 2013 5:11 pm
Seriously Limited wrote:I've run a couple of 5 series BMW's for the last 13 years. I thought some of the parts for them were a bit on the expensive side, but Connect parts are off the scale.
I agree they are pricey
Just like the wheel arch clips are priced at £4.99 each from Ford which is odd :?
You can buy complete front wheel arch trim complete with clips for connects from 2006 onwards at £20 (trade) each direct from Ford.
Which reminds me. I will have aload more arch clips available due to replacing my rear wheel arch trims.
FREE to anyone who wants them, just pay for p&p.
paul2012
Postby SteveO » Mon Jul 08, 2013 12:10 am
You have a pm Paul.
SteveO
Postby paul2012 » Mon Jul 08, 2013 12:52 am
SteveO wrote:You have a pm Paul.
PM sent :wink:
paul2012
