Lowered my connect.
Re: Lowered my connect.
Postby Kent Discos » Fri Nov 04, 2011 10:06 pm
good find paul!
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby connect_4 » Sat Nov 05, 2011 10:35 am
L200Lee wrote:Andy: the front setup is a pain in the arse, you can try the passion ford forum for the springs as they usually have a mk1 rs being broke, or a few spares. OR, Mylee was starting a group buy for some custom springs that where basically the same profile and compression rate as the RS ones but with connect tops, so no need for cups and bearings, drop him a pm to see if it's still available.
Hope that helps :D
Nice one, thanks very much.
connect_4
Postby connect_4 » Sat Nov 05, 2011 11:00 am
valetech wrote:have spoken to my ford dealer today.have been told the mk 1 rs runs the same setup as a standard focus but just lower springs
so you can use the standard top cups (part number is the same for rs and standard) £26 each from fords or use your local breakers
springs- try using lowered springs for a standard focus or ford can supply you rs spring for £80 each
My local breakers has a couple of Focus's in so i'll get the cups from there and clean them up, and try some lowering springs.
thanks for your help.
PS : HOW MUCH DOES THE FOCUS RS SPRING SET UP LOWER THE CONNECT BY ? - JUST SO I KNOW WHAT LOWERING SPRINGS TO BUY IF I CAN'T GET ANY RS ONES.
cheers
Andy
connect_4
Postby valetech » Sat Nov 05, 2011 11:53 am
Hope my Ford dealer is right
molested by:
19s is how we roll
valetech
Postby L200Lee » Sat Nov 05, 2011 11:58 am
cheers
Andy[/quote]
I think your looking at about 40mm lower on the front.
Ps: Paul your right about the standard focus tops and bearings, I asked the same question to my local ford dealers :D
I like to think This forum was a boring place until I turned up!
L200Lee
Postby Honey monster » Sat Nov 05, 2011 11:58 am
Honey monster
Postby van mann » Sat Nov 05, 2011 2:11 pm
valetech wrote:Hope my Ford dealer is right
He is right.All focus models cups,mounts and bearings are the same.Just the focus rs springs are different.I got 2 focus legs from the scrapyard for £30 and FOCUS RS springs off ebay for £30
van mann
Postby valetech » Sat Nov 05, 2011 2:30 pm
Did you put the springs from the legs with the rs ones to see the differents? Is it just the height?
molested by:
19s is how we roll
valetech
Postby connect_4 » Sun Nov 06, 2011 1:47 am
So the RS front spring lowers the connect by 40mm - is that all ?
Could the standard connect front spring just not get cut down ?
Anyhow, looks like i'll be getting some standard focus spring tops and bearings from the breakers and some focus lowering springs, i wonder if focus -35mm springs will be ok ?
connect_4
Postby valetech » Sun Nov 06, 2011 8:24 am
No you can't cut the springs down unless to want to fail the mot
35mm lowering springs will do the job
molested by:
19s is how we roll
valetech
Postby Mylee » Sun Nov 06, 2011 9:18 am
Do a search, one guy on here cut his front springs to match the rear end lowering. Looked good, if a little to low.
A little while after, he reported that the van drove like a pig and had two leaking front shocks due to them bottoming out. :?
Mylee
Postby connect_4 » Sun Nov 06, 2011 10:49 am
I will get the lowering springs, it's the sensible thing to do.
cheers
Andy
connect_4
Postby connect_4 » Sun Nov 06, 2011 10:50 am
Mylee wrote:Do a search, one guy on here cut his front springs to match the rear end lowering. Looked good, if a little to low.
Thanks, i just read that, i'm going for the correct option. - no cutting.
connect_4
Postby belly » Sun Nov 06, 2011 11:36 am
My old pug 306 hdi had 60mm gti6 lowering springs on, the reason I did that was they were the lowest springs I could get and being a diesel the car actually dropped about 70mm due to the diesel being a heavier lump, looked great but wasn't very practical you felt every stone and it ate arb links :lol: So what i was getting at won't the petrol focus springs drop more than 40mm ? More like 50mm :D
belly
Kaiser Chief
Postby van mann » Sun Nov 06, 2011 3:50 pm
The focus rs and standard focus springs are the same design.Just the spring rating is different.You could just use standard focus lowered springs,although you would have to buy all 4 just to get the front 2.
I would recommend to keep searching e-bay .I missed out on a set but another set came up a couple of weeks later.
Or bite the bullet and go to ford.
This is what you need.
FOCUS RS springs
Standard focus cups,mounts and bearings.
van mann
