MrC wrote:Also when no belt was on the wheel, it did wobble very slightly and appeared to be rather worn out - tiny hairline fractures all over, though my eyes may have mistaken me, could just be debris imprinted on it. Does anyone know if it's possible to adjust the alightment of the tensionerIf so, is it something I can do, or better to ask a garage
Perhaps it's not the tentioner but one of the wheels next to it
So... it didn't work!!
The brand new belt stopped it squeaking for about a day, then it came back to haunt! So, it must be the tensioner wheel bearing which is making the noise, given my observations (copied above).
Is this a common problem???
Am I right about the belt running off to one side of the tensioner wheel?????
Can anyone take a look at theirs to check for me????
If the belt is always off to one side (not just mine!) then that would explain it being a common problem
If the belt being off to one side is a symptom exclusively to my Connect then, perhaps someone has fitted the wrong tentioner at some point.
