Subframe removal
Re: Subframe removal
Postby Boghopper » Sun Jun 30, 2024 8:23 pm
I will try and get the anti-roll-bar off tomorrow, if I can the subframe will then drop down.
I went this route after reading the answer to the initial thread, starter question.
yes they do come out, lower the subframe a little to allow enough space to get socket in and it should come undone
Getting the steering rack bolts out was easy, and I thought I was on my way. But no-one menrioned the rack it entwined in between the anti-roll-bar.
There is a little, 6mm nut, on the Driver's side that clamps the power steering pipes to the subframe, a real turd to get to and it stops the subframe lowering. Took me a while to figure out what was stopping it lowering.
and look at every component you take off as time to service, clean or replace. to assure longevity of the van
That means every thing you do is a bonus to the van and ensures a long future for it.
I have been doing that for years. These bolts are the last bolts, on ther underside this van, that I previously had not touched. After this there will be nothing under this van that doesn't have copaslp on it.
You'll probably find it needs a whole host of things like bottom ball joints, wish bone bushings.
I am putting new Lemforder wishbones on and new anti-roll-bar bushes. My driveshafts are pretty new, as are my wheel bearings. I rebuilt all that a few years back, along with rebuilt calipers. My nearside driveshaft has been destroyed now, though. So, that will have to be replaced. I only put a new one on last year when changing the gerabox.
Boghopper
Postby metalworker0 » Sun Jun 30, 2024 8:40 pm
don't know if this works
ive just uploaded this to google docs
https://docs.google.com/document/d/1Ylc ... sp=sharing
Postby Boghopper » Sun Jun 30, 2024 9:00 pm
Yes, that's the Ford manual, and method. The way I should have done it and recommend anyone else to do it, as the 'leave the steering rack in' method doesn't work.
Boghopper
Postby Boghopper » Mon Jul 01, 2024 12:07 pm
I disconnected the steering wheel and drained the fluid, at the rack, this morning. The whole lot dropped out easy once that was done. I did try and loosen the anti-roll-bar caps and twist the bar backwards, to allow the track-rods to become unentwined, but that never worked either.
Just should have done it that way in the first instance.
Boghopper
Postby metalworker0 » Mon Jul 01, 2024 8:06 pm
well i was lucky to find the manual ..and could only look at that section of the manual from a search on google ..you cant search the manual as it blanks you out ... 9 times out of 10 i get the wrong section or it only covers half the job. so lucked out . screen grabbed it and plonked it in MS word and uploaded it .
glad you have it half done
how about some pictures of the damage
have you got a replacement yet
Postby Boghopper » Tue Jul 02, 2024 7:23 pm
I have it on disc, if you want a copy. Needs running on VMware though. There isn't much damage realy, only the snapped subframe, which, once off, has quite terrified me. I never realised what a s""t-state it was in. And the driveshaft is snapped, at the inner C.V. joint. The arch liner has a groove gouged in it. I will put a picture up of the subframe, though, in the other thread. The steering rack seems okay, but as my van has done , knocking on 90,000, I am going to replace it with one I purchased, nigh on, ten years ago.
Boghopper
Postby metalworker0 » Tue Jul 02, 2024 9:02 pm
The only thing knocking 90.000 here is my hard drive, it done its reset to zero hours at 65,535 and then another 29,000...no don't bother with VM , it would probably have coronary on windows 7.
Postby Boghopper » Tue Jul 02, 2024 9:45 pm
I'm running Windows 7, far better O.S. than the spyware/ bloatware messes that have followed it.
Boghopper
Postby Boghopper » Fri Jul 12, 2024 11:56 am
Wrong thread!
Boghopper
