how long for heater to get warm
Re: how long for heater to get warm
Postby gt_addict » Fri Dec 14, 2012 6:04 pm
I thought covering the rad would decrease the airflow into the engine bay to aid a speedier warm up?
gt_addict
Postby winterheating » Fri Dec 14, 2012 7:29 pm
What does the new focus have auto vents on the front grill for....
winterheating
Postby winterheating » Fri Dec 14, 2012 7:32 pm
The heat transfer from the rest of engine is going to be really really low, compared with a radiators heat transfer.
winterheating
Postby Adam_84 » Sat Dec 15, 2012 12:15 am
What about fitting an under tray to help keep the warm air around the engine with it venting out the back like most cars have? And a bonnet blanket
Adam_84
Postby winterheating » Sat Dec 15, 2012 1:23 pm
Drive it normally straight off, so under normal load.
Check coolant levels correct,
Check thermostat isn't passing to rad straight away.
If all that is fine, possibly a slipping water pump.
winterheating
Postby CHADVALLI » Sat Dec 15, 2012 6:39 pm
Change Yellow cap on Expansion Tank
CHADVALLI
