P0490 egr question
Re: P0490 egr question
Postby onejay » Tue Jun 24, 2014 10:43 pm
any idea what size the hole is
onejay
Postby liteace » Tue Jun 24, 2014 10:45 pm
onejay wrote:any idea what size the hole is
Start with 8mm, try it, if no good go up to 10 to 12mm
liteace
Postby onejay » Tue Jun 24, 2014 10:46 pm
cheers mate,i will try it tomorrow
onejay
Postby liteace » Tue Jun 24, 2014 10:46 pm
onejay wrote:cheers mate,i will try it tomorrow
No problem, hope it works, fitting the correct (with hole) or making hole should solve the problem
liteace
Postby onejay » Tue Jun 24, 2014 10:51 pm
had a look on ebay
hole is 10mm
thanks again
i will post up the result
i hope its good news
onejay
Postby bertye » Sat Feb 13, 2021 10:47 am
The P0490 is nothing to do with a blocked EGR. It is an electrical problem. The 1.8 Linx engine does not have a problem being fully blocked, both the Euro 3 and the Euro4. The only time having the EGR blocked is a problem, is when there is also a boost leak, like a small split in one of the hoses or intercooler.. It would be best to look up the code rather then guessing that is it due to a plate and that t needs a hole in, as the electrical problem will still be there. Check the link
https://www.obd-codes.com/p0490
bertye
