Clutch slave cylinder symptoms / diagnostic
Re: Clutch slave cylinder symptoms / diagnostic
Postby Timelourd » Fri Jun 09, 2023 6:53 pm
metalworker0 wrote:inside the bell housing would normally have dry black coating after so long ...yours is very wet ..so there is something wrong! ..slave cylinder, that loctite seal what was talked about ...or the crank seal
and if the clutch hasn't been changed in 25,000 ..a new one should be going in .
so change the lot .
So, I took off the slave cylinder, and as expected, no sealant or hint of loctite anywhere. Also, the cylinder is a flimsy plastic number, no steel ring at the union. So I'm going to bin that and put on my new one with steel ring and proper sealant.
The clutch action has always been smooth, until the (possible) slave cylinder failure, so I reckon someone replaced the clutch and put in a new slave recently... they just chose an inferior slave cylinder and didn't put any loctite so it failed/let in brake fluid.
But I won't be certain unless I put it all back together and turn it on.
1996 2.5di MK5 Banana Engine
Timelourd
Postby Kenton » Fri Jun 09, 2023 8:09 pm
so change the lot .
Replace a clutch at 25k?? :shock: Really??
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby metalworker0 » Fri Jun 09, 2023 8:25 pm
Yes, its lots of work to get to where he is, massive amount of work, hell of a job if you are doing it yourself with no ramp. ..and some clutches wear out in 75,000 miles
just saying .....I wouldn't like to be doing it again ..in perhaps January in a couple of years time
Postby andz327 » Thu Jun 15, 2023 12:40 am
Timelourd wrote:
andz327 wrote:If the orange o-ringed end is into master cylinder it will seem like faulty master , probably why you still had problem after changing master cylinder
At least try it before spending more money
Sent from my SM-G975F using Tapatalk
Can you explain more about what you're suggesting I do? I have checked the seals on the fluid hoses and they're fine. What orange o-ringed end? Do you mean the rusty one with the purple o ring in my pic?
Yes sorry the orange/rusty looking one, just cause there's an O-ring on it doesn't make it right it'll draw air without correct seal...... I know first hand about these seals drawing air on mk7 2.2 fwd clutch pipes , please look again it's not an O-ring it's longer
andz327
Postby andz327 » Sun Jun 18, 2023 10:59 pm
Any joy ???
andz327
Postby andz327 » Fri Jun 23, 2023 12:02 am
Hello??????
andz327
Postby Timelourd » Fri Dec 22, 2023 3:00 pm
Yeah I replaced that slave cylinder with new anarobic sealant and it works like a charm. No clutch issues - my hunch was right. New clutch but the previous mechanic's silicone sealant just failed and slave cylinder had a ruptured seal.
Thanks everyone for their help.
Timelourd
Postby Timelourd » Fri May 31, 2024 2:05 pm
After I fixed this (last December) went to drive to the MOT inspection and the clutch petal went back to the floor again.
Been back out there trying to bleed it today, but no fluid comes out the bleed nipple when I pump the clutch pedal.
However, fluid does come out if I unplug the input pipe from the slave, so I know the master is pumping.
Going out to try bleeding it again. Not sure what's wrong. I really don't want to take the transmission off again. Hoping it's a hose, but there are no signs of other leaks elsewhere.
Timelourd
