You could ask the dealer to see if they can get a copy of the service history for you (you never know, they might be helpful
Heres a copy of the extended period maintenece operation, just to see what extras are on top of the service checks
Select Extended Period Maintenance operations
Check the boxes below to include these extended period maintenance operations
Brake system - Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning - Every 3 years - Check temperture at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system - Every 4 years - Check/clean pressure cap, renew if there is seal deterioration
Cooling system - Every 10 years - Orange/pink coloured coolant. Drain, flush and refill with purple Super Plus (LTS 24 122 4)
Cooling system - Every 10 years - Drain, flush and refill with purple Super Plus (LTS 24 122 4)
Camshaft drive belt - Every 150 000 miles/10 years - Renew (LTS 21 304 9)
Auxiliary drive belts - Every 150 000 miles/10 years - Renew
Visual Body & Paint Check - Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above - see detailed Check Sheet - if applicable (LTS 54 555 1 +)
