metalworker0 wrote:i put mine on google drive
if you are in the position were you have to log into google. then google drive is free to use , ive put files on there that are 90MB
https://drive.google.com/drive/my-drive
btw .. must be a PDF, as most common for most people to have this reader only
Hi Mark, today im going to check if i see somsthing or test something with forscan. I also have the thinkcar car scanner, maybe that one sees something wrong.
If I do not get this fixed the normal way I will fix this myself. i will buy thick wire and use the relays that are now in the car ta make my own timed module with a button inside.
I will install also heated mirrors when am ar it... one button that does it all and shuts down with a timer.
If i have to bring the car for maintenance to Ford for this problem, this is going to cost alot of money...
About the google drive, I will do that and I will provide the share link here... will do this later today.
