Anyway, I still cannot remove the last glow-plug even though I have een soaking it in Plusgas for over a week and trying it with the torque wrench set to 15nm with the engine hot, still won't budge: obviously poohing it, about it snapping. It passed M.O.T. as the glow-plug error is not an M.O.T. failure. I have to say that these glo-plugs have nothing to do with the starting of the vehicle. Mine are all knackered and have been for a while but, the van starts perfect, maybe a bit smokey in the winter, that's all.
My A.B.S. code was sorted out by changing the front sensor, could see no physical damage to the end and there was 12v getting to it at the feed connector. I stuck the air-line down the sensor hole, in the knuckle and blew out a bit of muck thrn replaced it and that was that. That Forscan was good as it told me the exact sensor that was wrong. Made me realise how archaic that ForDiag, that I have been using, is.
I had another code ACM B1342-40. Which was telling me to see the dealer and it was just because the code had not been entered into the stereo, what a load of nonsense!
There are 200 Ford dealerships being shut down and one of them is the one near me. It is the second oldest Ford dealership in Britain, and has been a garage for over 120 years. So, that is going to cause me no end of problems, the joys of Cultural Marxism. Hold onto your hat as the next puppet to be installed is an even extra radical Bolshie and things are going to get bad! They're shutting down the factories just when all the rent is due!
https://dunnets.co.uk/My other vans two main rails were stripped down to the metal. I put cold galvanizing primer on them, then, 2K epoxy on top, then, vapourmatic paint, then, synthapruf, then, UPOL gravitex. Lasted two years, up here, before being stripped and rust showing through.
My centre exhaust has only done two winters and is nearly through on the lower bends so, have had to take that off as well.
Was thinking of buying all the bends and box in stainless and getting a TIG but it seems pretty involved with all this purging gas and helium mix.
I have a decent MIG and have been reading about welding stainless with the MIG, using stainless wire, don't know how feasible that is though. 304 stainless seemd to be a great deal harder to weld and is prone to fracture if bodged up.
Both my rear calipers have seized and the lower edgwe of the pistons have been eaten away so, the rubber boot won't fit back on. They were brand new 3 years ago!
Fifty quid for a pair of new calipers and £42.00 for a rebuild kit! These green zealots make me laugh as they make everything throw away whilst insincerely prattling on about recycling. They always weem to be driving around in brand new vehicles as well.
