Took the van back today and he used a different ignition feed from the can bus interface and it worked but after 20 mins the steering stalk controls stop working, he phoned the company that produce the can bus adapter and they advised try another one first and if that doesn't work it means the van wiring for the can bus is going to sleep or semi sleep as it cant see anything so they will have to make something up, they will come from the Midlands to W Wales to solve the problem as it must be a first and nothing is listed for the Connect just Focus etc
Apparently the wiring is different on the 08/06> connects from the previous and its a right pain according to the installer, at least im getting my moneys worth
I will be trying another adapter in the new year when I going near the dealer as they are 50 miles away, one of the problems with living in the sticks!
Also he only grounded the handbrake cable and it all seems ok, told him about the 2 wire bypass and he never heard of it saying he has done thousands just using the handbrake grounded. Love the sat nav first one ive used that found my address
I will be getting a Hertz EP1D sub amp as my Hertz Mille sub is causing my front and sub amp (4 channel) to get hot and go into protection mode after about 45 mins of hard use. Should only go down to 4 ohms bridged and the Mille sub is 3 ohms on my meter and on the website is says 2.5 ohms although its 4 ohms on the sub! I thought it would be hit or miss as the sub is rated at 600w rms and the amp is only 190 rms and this can cause problems when at full power, I will just put the 4 channel amp into bridge mode so its only 2 channel @ 190 rms each and try to only put 100 rms into each of the front components so the amp should then run warm only.
I had a demo of this sub amp on a lower model hertz sub and it was just silly amounts of bass, better be nice to the mrs as its £380 and ive already spent quite a bit.
Still havent worked out how to cover the head unit?
