Hal wrote:SirKit Breaker wrote:You are correct about the cutout at the top of your lefthand door in Europe a high level brake light is fitted.
Wonder why they didn't use it over here instead of adding a separate high brake light on the roof?
US State laws requite it to be in the centre.
Getting back to the fog light question, the" juicers" you have in the front bumper are molded in, and you will need to cut them out, if you need to fit lights, but you will also need the mountings that were never included on your model.
The light switch for front fogs will have 2 seperate pullouts, one for the rear, and another for the front fogs, and each will be illuminated, so this will mean another switch be purchased, or wire them up with the rears.
You laws are so different than ours, over here, its illegal to drive with the front fogs on unless there is fog or falling snow.
