NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby gt_addict » Mon Aug 26, 2013 3:22 pm
Oh well. It's still lower revs than the old box I had so gives better economy.
If you could post the results that would be great. It would be now to see the difference :)
gt_addict
Postby paul2012 » Fri Aug 30, 2013 12:03 am
When removing engine, it can be easily removed from the top complete with gearbox attached. :wink:
Before lifting engine, remove the following
Disconnect all coolant hoses & remove radiator assembly
Unbolt the cat, remove inlet & exhaust manifold with turbo.
Power steering pump & alternator.
Battery tray
Both fuel pipes
Unplug the 2 electrical connection plugs on top of gearbox (2003-2006)
Disconnect both gearshift cables
disengage both driveshaft's & remove them (Don't forget Clutch Pipe)
Uses suitable engine hoist & load level to take weight of engine & gearbox
Remove engine & top gearbox mount completely
Remove the single bolt for rear lower gearbox mount.
Using a load level lower the gearbox end first before proceeding to lift whole assembly.
Once engine is clear from O/S chassis rotate engine & box slightly so it clear from N/S chassis.
When clear level the assembly using the load level then lift clear from vehicle.
I didn't have to remove my front bumper 8)
Not removed old wiring loom or clean engine bay yet :oops: (Too busy sorting my drive out)
Gearbox doesn't look that old, It's still got the label on it :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Fri Aug 30, 2013 5:59 pm
Well back to project :mrgreen:
New Power steering feed pipe has arrived - fits between pump & rack
Along with 2011 Focus gearbox which was a steal at £75
Only done 2638 miles according to ticket attached :D
Once engine bay has been cleaned down & later wiring installed with ABS pump, then Engine & box can be fitted :wink:
paul2012
Postby SWtechnologies » Fri Aug 30, 2013 7:41 pm
paul what is the advantage of the 2011 box? im due to change a clutch out in mine and was wondering weather to look for a better box!
thanks for your posts!
SW technologies
SWtechnologies
Postby Vacuumsealed » Fri Aug 30, 2013 9:05 pm
Looks like you've got some serious technical knowledge Paul. Personally wouldn't know where to start! I don't give a sh*t about Pulse Modulations etc and if you want to spend your cash on what seems your hobby, then good on ya.
I doubt many, if any would invest in a project like this and most, including me, couldn't if they tried.
Lookin' good.
Vacuumsealed
Postby paul2012 » Fri Aug 30, 2013 10:59 pm
SWtechnologies wrote:paul what is the advantage of the 2011 box? im due to change a clutch out in mine and was wondering weather to look for a better box!
Thanks :wink:
With this Focus box 6M5R 7002 ZD (Ford Part No F1706941) Ratio 3.41
Firstly instead of racing through the short gears on the connect box, this one they are longer.
Ideal when on motorways cruising at 70 you engine speed could be as low as 1700 RPM The advantage would be fuel economy,
Mainly due to engine will no longer be racing away as it does with the connect box :wink:
paul2012
Postby paul2012 » Fri Aug 30, 2013 11:27 pm
Vacuumsealed wrote:Looks like you've got some serious technical knowledge Paul. Personally wouldn't know where to start! I don't give a sh*t about Pulse Modulations etc and if you want to spend your cash on what seems your hobby, then good on ya.
Lookin' good.
Thankyou, still loads more work to be done yet :wink:
I agree reguarding the PWM fiasco, a lot of people tend to blank of EGR valves so it's irrelevant & can be confusing hence why I never went into detail about it until now.
paul2012
Postby SWtechnologies » Sat Aug 31, 2013 9:51 am
Thanks :wink:
Thanks for that I may look out for one then! Where did you get yours? And do you use the same clutch as normal?
SW technologies
SWtechnologies
Postby paul2012 » Sat Aug 31, 2013 1:58 pm
Thanks :wink:
I got my one from Ebay, & yes you use the same clutch assembly fitted to connects - Put a new 3 piece clutch kit in when fitting a new box
There's a gearbox available here :arrow:http://www.ebay.co.uk/itm/FOCUS-MK2-MK3 ... 27cc8d327c
paul2012
Postby paul2012 » Sat Aug 31, 2013 7:57 pm
Back to project again :roll:
Removed old wiring loom from engine bay
Also finally cleaned engine bay down, looks a lot better than it did before :D
paul2012
Postby BIG E » Sat Aug 31, 2013 8:20 pm
What did you use to clean your engine bay fella?
BIG E
Postby paul2012 » Sat Aug 31, 2013 8:38 pm
BIG E wrote:What did you use to clean your engine bay fella?
I used comma hyperclean, brush on leave for 10min & rinse off :wink:
paul2012
Postby BIG E » Sat Aug 31, 2013 8:44 pm
I think i'm going treat myself to some of that,looks like its good gear.
BIG E
Postby paul2012 » Sat Aug 31, 2013 10:14 pm
BIG E wrote:I think i'm going treat myself to some of that,looks like its good gear.
It is very good stuff, cuts through oil & grime with ease
paul2012
Postby tez » Sun Sep 01, 2013 2:02 am
paul2012 wrote:Back to project again :roll:
love to no hw much this has cost u so far would ff be cheaper just to get new van as u not going to get your money bk what u hv spent on it are we :shock:
tez
