Toffee wheels a cracking bit of kit for your tool box. I used one on a rear window i fitted for a member on here to get rid of some nasty smeg someone had used to try and seal the window
BIG E wrote:Toffee wheels a cracking bit of kit for your tool box. I used one on a rear window i fitted for a member on here to get rid of some nasty smeg someone had used to try and seal the window
Vacuumsealed wrote:
So when are you going to sell me the cab ceiling shelf? !!!
paul2012 wrote:
As for other Tourneo bits, there one here being broken up for spares
http://www.ebay.co.uk/itm/Breaking-FORD ... 51b1e27652
BIG E wrote:Are the clips that hold the headlining in oncers Paul? I want to take the lining down to insulate it this week and if i'm going need clips i'd rather order them before hand![]()
paul2012 wrote:Time to sort out the dash loom![]()
Now before It can be fitted, I have to patch in all this 2009 onwards equipment.
Into this 2007 dash loom.
It's fairly straight forward, most of wiring is already there, just going to the wrong place.
For example wiring for wipers- On connects from 2003-2009 they are controlled by instrument cluster (intermittent wipe) where on connects from 2009 onwards they are controlled by the GEM module located behind fuse panel on N/S.
So Wiring has to be disconnected from instrument cluster plugs & chased back to Fuse panel & bulkhead Plugs that's connects to engine bay loom.
This will take a few days to complete.
Time consuming part is finding the relevant wiring that needs to be changed then label it. Then pulling the whole loom apart to change its route or added before taping loom up.
This way I will end up with just 1 loom to fit, instead of adding a subloom like I did when I first retrofitted all equipment to the old 2004 loom.
g-man wrote:whats elc st br cnt
