EGR blank tips/help
Re: EGR blank tips/help
Postby g-man » Mon Oct 08, 2012 11:50 pm
tante wrote:I blocked the EGR off last week on my transit connect sport with a little peace of metal i got of ebay run it on a full tank and made a little diffrence but was poor on the motorway so slow took it out again today and feel like a rocket again we see how we go this week.
did u disconnect the vac pipe when u blanked it?
g-man
Postby CamsTrans » Mon Oct 08, 2012 11:56 pm
Some good thoughts on this forum. I don't like the sound of my engine temperature rising; I'll just see Martyn :lol:
http://www.astraownersclub.com/vb/archi ... 56097.html
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby Graham Taylor » Tue Oct 09, 2012 11:06 am
CamsTrans wrote:Some good thoughts on this forum. I don't like the sound of my engine temperature rising; I'll just see Martyn :lol:
Just read that thread quickly and the arguement does fade and TBH I have never heard this stated before. I have mine blanked and since doing this I think the van is a little more "snappier". I also fitted the Focus airbox which sucks in more cold air.
Graham Taylor
Postby tante » Wed Oct 10, 2012 8:37 am
I booked it in ford now :)
tante
Postby Adam_84 » Thu Oct 11, 2012 4:03 pm
So which pipe gets pulled off and blanked?
The one with the white line on it or the other little one?
Cheers adam
Adam_84
Postby g-man » Thu Oct 11, 2012 4:10 pm
mines got the later egr so its different.......but it looks like the small dia black one going to the back.....if u take that jubilee clip off and remove the rubber inlet there should be a butterfly valve,normally open,that vac pipe closes it down when its recirculating the crap
g-man
Postby Adam_84 » Thu Oct 11, 2012 6:23 pm
Sweet cheers g-man, will disconnect it.
Adam_84
Postby C8XY » Thu Oct 11, 2012 8:54 pm
I fitted mine and the van feels like it misfires when I accelerate, especially when cold. Do I need to disconnect a pipe?
Mines a '07 TDCI 75, no warning lights on the dash.
If this is a normal trait with the blank then its coming out!
Cheers R
C8XY
Postby gt_addict » Thu Oct 11, 2012 9:21 pm
I'm not sure if you need to disconnect any vac pipes on the early EGR valve (UFO looking thing). I haven't and mine still runs fine with a blank plate in. I think it's the later EGR valves (hoziontally mounted) that need the vac pipe taken off.
gt_addict
Postby Adam_84 » Thu Oct 11, 2012 10:02 pm
I'm not sure how mine is running as my ecu is winging its way to vantuner ;-)
Adam_84
Postby Graham Taylor » Thu Oct 11, 2012 10:25 pm
I didnt disconnect anything when I blanked my 05 van and not had any problems.
Graham Taylor
Postby Connect-rick » Thu Oct 11, 2012 10:32 pm
From what I've read, the TDDI with the solid blank plate mostly runs fine with no issues.
The TDCI with the blank plate with the 5mm hole are prone to little problems like management light and lumpy running.
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby g-man » Thu Oct 11, 2012 11:01 pm
Connect-rick wrote:The TDCI with the blank plate with the 5mm hole are prone to little problems like management light and lumpy running.
no probs with mine......yet, been done over 2yrs :wink:
g-man
Postby C8XY » Thu Oct 11, 2012 11:04 pm
I think mines the newer type so I'll buzz a small hole in it tomorrow, cheers 8)
C8XY
Postby Connect-rick » Thu Oct 11, 2012 11:17 pm
I missed 'some' out when I posted! *some are prone....
That's what I've concluded anyway lol
2006 white 75ps
EGR blank
Connect-rick
