dye29 wrote:hy all again im a lucky guy been driving my van and when i give it abit or up steep hills it juist revs as if clutch is slipping why would this be doing it as its a new clutch could it just need bleeding
If it's slipping it will more then likely have to come out again.
Possible causes.
Contamination from oil
Flywheel not cleaned before fitment
Pressure plate not cleaned before fitment
Pressure plate clamping force not enough so defective part
Friction plate in wrong way round ( will normally not get gears when running though )
There is no adjustment that can be done on the clutch system.
You could try slipping the clutch a bit and see if it clears. Some clutches especially performance ones can slip slightly until bed in so maybe also try using it and get a few miles on it and see if it gets any better
Hope that helps
