Ignition Warning Light Comes on after 30 seconds!! HELP
Re: Ignition Warning Light Comes on after 30 seconds!! HELP
Postby Altransit » Fri Jan 29, 2010 11:15 pm
These ECU's come up on Ebay quite a lot, usually around £70, if your guy wants it sorted :)
Postby bortaf » Fri Jan 29, 2010 11:48 pm
That sounds better than what ford quoted him :lol:
do they need coding to the immobiliser? i try to avoid moderns TBH
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Altransit » Sat Jan 30, 2010 12:31 am
bortaf wrote: do they need coding to the immobiliser?
Yes they do unfortunately, and you also need to get the correct one, they have a code written on the outside of the case :wink:
Postby bortaf » Sat Jan 30, 2010 12:47 am
Cheers, got the code written down somewhere from when i took it out last week, i'll give ebay a scan tonight :mrgreen:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby WayneB73 » Wed Nov 11, 2015 9:11 pm
To be fair my battery light has been staying on for over 3 years now. In that time iv had the battery and alternator replaced when wouldn't start but haven't had any other problems.. Iv had the garage check it and they can't find any faults.
WayneB73
Postby sixaxles » Sun Dec 27, 2015 11:01 pm
well just to add to this thread, Christmas eve on the way to work in the dark, I put main beam on and on came my battery light, instantly assumed it was the alternator - on the way home it didn't come on until I put my lights on, had already pee'd the wife off royally by getting her to go to the local parts place and get me an exchange unit - including belt 150quid give or take the odd pound, so I was quite pleased it packed up again lol .... anyway, got the festive celebrations out of the way and fitted the new alternator today - surprise surprise the light came on again after thirty seconds of running, turned it off, started again and it came on again after thirty seconds..... very unhappy! decided to search this forum, found this thread - removed the short wiring loom from the alternator and went in the garage and did a continuity test on the three wires - the blue one was not creating a circuit, removed plastic casing and there it was broken blue wire!!!!!!!!! brilliant!!! at least I know the alternator is now new!
sixaxles
Postby eggster71 » Mon Apr 03, 2017 8:24 am
Thanks guys.
Had this happening intermittently and progressively worse over the last year until the light was on constantly following the 30 sec delay.
2 hour drive this morning after chopping out and reconnecting a previous repair to the loom yesterday. Not a single flicker. 8)
eggster71
Postby Carter21 » Sat Mar 18, 2023 9:18 am
Hi,
I'm having the same issue with the battery light. I see a lot about the loom, would anyone have a photo of a link of the type need as I have a 2014 connect but all I can find is the mk1 version. Thanks
Carter21
