NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Sat Nov 09, 2013 6:52 pm
camper-man wrote:WOW-I have just read this from start to finish I must say what a fantastic job I am new to transit connects (but not transits) and this has got to be one of the best builds ever. :) :)
Thanks :D
There a few more bits & pieces to work on, although the vast majority is completed :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Sat Nov 09, 2013 7:03 pm
Refitted dash & temporarily fitted steering column to plug in switch gear.
So far everything checks out ok & all working perfectly - including automatic wipers & headlights :D
Still looking for a pair of door cards, my current ones don't match the colour of dash (Dark Pewter) :oops:
Require a pair from a 2006 onwards connect in dark pewter (for elec windows) :wink:
paul2012
Postby paul2012 » Sun Nov 17, 2013 8:20 pm
After clearing old DTC's, programming PATS(immobiliser) including erasing 2 keys & recoding them (W1 carbon chip)
Finally Fired up engine today. Unfortunately I now have a couple of electrical issues :(
Alternator warning light is on when engine running DTC P0622-68 Generator Field Terminal Circuit - Invalid Signal (shown below)
I'm using the same alternator which was fitted to previous engine, warning light was on even then (goes off when engine is started, then light comes on around 5-10 seconds later)
I assume alternator is faulty :?: As brand new smart charge loom has been fitted
Glow plug feed wire overheating - Possibly down to 1 or more faulty glow plugs :?:
Other than the above engine seems to be running perfectly & is a lot quieter than the previous engine :mrgreen:
paul2012
Postby gt_addict » Sun Nov 17, 2013 8:31 pm
Good news. Well about it running anyway :lol:
gt_addict
Postby phil drew » Sun Nov 17, 2013 8:43 pm
has the arse come down by much with those springs or do you think its a less attitude as maybe softer ride
phil drew
Postby paul2012 » Sun Nov 17, 2013 9:02 pm
gt_addict wrote:Good news. Well about it running anyway :lol:
I agree it is good news, I'm pleased engine starts & run while it's still under warranty. Other 2 faults should a relatively easy fix - I hope :?
phil drew wrote:has the arse come down by much with those springs or do you think its a less attitude as maybe softer ride
Rear ride height hasn't reduced by much, approx 30mm & will proberly drop further once taken on the road.
At the moment it's been standing so do not know how it handles yet. :oops:
paul2012
Postby paul2012 » Fri Nov 22, 2013 9:27 pm
AIrbag problems B1877 - For drivers Seatbelt pretensioner :roll:
Spent all yesterday afternoon Checking & rechecking everything & still get DTC B1877 :?
Seatbelt pretensioner itself is fine - 2.5 ohm as it should be. Wiring checks out ok, except when pluged into seatbelt no reading at all :evil:
After inspecting the internals in the plug, there's a capacitor fitted !
Plugs for seatbelt pretensioners on 2009 onwards connects have a Ferrite inductor (choke) instead
Plug at the top is from my 2007 connect body loom
Only solution to solve problem, is to change seatbelt pretensioner loom to 2009 onwards.
Luckily I managed to grab a intact wiring loom complete with plug for seatbelt clasp (seatbelt reminder light/chime) from local breakers from a 2011 connect
Ideal part no wiring involved simply plug & play
Bigger bonus finally bagged the forward section of brake pipe from ABS pump to rear - which Ford no longer lists :(
Also vac pipe to brake servo with T-section for Throttle shut off valve - another part Ford no longer supplies (revised version does not have T-section)
paul2012
Postby bonny222 » Sat Nov 30, 2013 9:24 pm
first time I have see this its a shame he does not live in the north he could sort my van out good on yare Paul
bonny222
Postby paul2012 » Mon Dec 09, 2013 8:09 pm
bonny222 wrote:first time I have see this its a shame he does not live in the north he could sort my van out good on yare Paul
Thanks :D
Unfortunately I'm in Norfolk
paul2012
Postby paul2012 » Mon Dec 09, 2013 8:30 pm
Now I have a few days spare, time to get on with my connect :D
Fitted last brake pipe from ABS pump to first union for the rear & Vac pipe to brake servo
Purchased sub wiring loom for heated washer jets - Ford part No F5191790
Old washer jets to be removed
New ones fitting along with Sub loom. All holes for plug/loom clips are already there :wink:
Subloom connects onto the wiring for wiper motor / heated screen - Plug is located under N/S scuttle panel (Blue wire with plug is 1 of 2 for the heated front screen)
Bonnet sound deadening /insulation cleaned & refitted :D
Thinking of a way to insulate washer bottle before refitting it :? May help prevent it from freezing during winter (freezes even with screenwash) :(
paul2012
Postby gt_addict » Mon Dec 09, 2013 8:50 pm
Do they do mist washer jets specifically for the connect as I've got a set for a focus and the spray angle is slightly low for optimum windscreen coverage?
gt_addict
Postby nardi » Mon Dec 09, 2013 8:54 pm
paul2012 wrote:Now I have a few days spare, time to get on with my connect :D
Wrap it in plastic bag and fill it with expanding foam ,the best insulation.
nardi
Postby paul2012 » Mon Dec 09, 2013 9:28 pm
gt_addict wrote:Do they do mist washer jets specifically for the connect as I've got a set for a focus and the spray angle is slightly low for optimum windscreen coverage?
Have not tried them yet, I have not refitted washer bottle :oops:
paul2012
Postby gt_addict » Mon Dec 09, 2013 9:33 pm
Well not being funny but the brake pipes are a tad more important :lol:
Good progress though mate.
gt_addict
Postby paul2012 » Mon Dec 09, 2013 10:29 pm
gt_addict wrote:Well not being funny but the brake pipes are a tad more important :lol:
I agree :wink:
Once I have tested washers I will post results here & yes these are specifically for connects :D
paul2012
