NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby gt_addict » Mon Dec 09, 2013 11:37 pm
Nice one cheers Paul. For reference the focus ones mainly spray just above the wipers. A fraction more towards centre and they'd be spot on for coverage.
gt_addict
Postby paul2012 » Wed Dec 11, 2013 8:33 pm
On the hunt for alternator today, no luck on that one all had gone.
Grabbed this bag for Jack/towing eye & wheel brace from a 2009 connect...
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby ishmail » Wed Dec 11, 2013 9:18 pm
paul2012 wrote:On the hunt for alternator today, no luck on that one all had gone.
i got mine from redcorn only £30 they only round the corner from me if you need i can have a look for you 8)
ishmail
Postby paul2012 » Thu Dec 12, 2013 6:40 pm
That's cheap for a alternator, reconditioned or new ?
I'm looking for a alternator :wink:
current one fitted is Visteon 2T1U-10300-AG (without air con)
paul2012
Postby ishmail » Thu Dec 12, 2013 8:46 pm
looks like same as mine but my van has a aircon im gonna look in to it tomorrow its from scrapyard pm me your number when im there i call you + where do you live paul ? im in north london edmonton
ishmail
Postby paul2012 » Thu Dec 12, 2013 11:10 pm
I'm in Norfolk, alternator can come from a engine with aircon as long it has coupling for Shaft assembly & not a pulley. :wink:
If they have one available let me know & we will work something out.
paul2012
Postby ishmail » Fri Dec 13, 2013 12:09 am
ok im on it will let you know tomorrow :) 8)
ishmail
Postby paul2012 » Fri Dec 13, 2013 11:19 pm
Changed glow plugs today.
Old ones here
Cured the fault of glow plug feed wire overheating :D
paul2012
Postby gt_addict » Sat Dec 14, 2013 7:32 am
So changing the plugs cured the wire overheating?
gt_addict
Postby Altransit » Sat Dec 14, 2013 1:26 pm
gt_addict wrote:So changing the plugs cured the wire overheating?
Makes sense, a lot of glow plugs do go short circuit when they fail :(
Postby gt_addict » Sat Dec 14, 2013 2:10 pm
How do you test them? Multimeter? If so what setting as I've never tested mine but never had any problems starting even when the wire had melted through.
gt_addict
Postby ishmail » Sat Dec 14, 2013 2:43 pm
hi paul i found one for £30 let me know because they go fast :)
ishmail
Postby g-man » Sat Dec 14, 2013 3:03 pm
i'd get them tacks picked up
g-man
Postby ishmail » Sat Dec 14, 2013 4:17 pm
i got it mate only £30
ishmail
Postby paul2012 » Sun Dec 15, 2013 9:28 pm
ishmail wrote:Image
Is that the alternator, looks fairly new.
It from Focus :( Battery cable is connected to the top
On connects battery cable location is on the back pointing towards starter motor.
Due to this my original battery cable is too short to connect to is (unless I change cable over to one from a Focus....
paul2012
