What did you do to your connect today?
Re: What did you do to your connect today?
Postby mrtn » Sat Jan 02, 2016 9:31 am
Which seller are you talking about?
1.6 Ecoboost A/T LWB '16
mrtn
Postby Graham Taylor » Sat Jan 02, 2016 10:38 am
mrtn wrote:Which seller are you talking about?
TPUK
Graham Taylor
Postby tez » Sat Jan 02, 2016 3:33 pm
TPUK
y yes
tez
Postby Hotwheels » Sat Jan 09, 2016 10:26 pm
tez wrote:
Hotwheels wrote:Here is a picture of my transit connect the next part is to change the front bumper to the 2009 onwards one any advice welcome cheers for now.
nice van m8 be better with a private plate :D
I have now changed the front bumper and done some more modifications I shall post some pictures next week when its finished cheers.
Hotwheels
Postby Graham Taylor » Sat Jan 09, 2016 10:42 pm
Did someone say looks better with private plates? Gonna cost you :-)
Graham Taylor
Postby tez » Sun Jan 10, 2016 1:55 am
Graham Taylor wrote:Did someone say looks better with private plates? Gonna cost you :-)
am like that gt :D :D
tez
Postby pushrod » Tue Jan 19, 2016 7:00 pm
Changed the oil. That was easy, but had to bend my arm in about 6 places to change the filter... :roll:
pushrod
Postby mrtn » Tue Jan 19, 2016 7:12 pm
New wipers (Valeo/Bosch).
Made the same error as the last time - got the factory size: 55/50 cm. As I have a banner on the top of the windscreen it clears at exactly 50 cm and consequently 50 cm is too long for the passenger side, the end is off the glass at the rest position. So I went back to the shop and got 45 cm for the passenger side and put the 50 cm one to the driver side. I'll put the factory size (55 cm) on the Connect wagon as it's also in the need for new wipers anyway and has no banner.
mrtn
Postby paul2012 » Tue Jan 19, 2016 7:57 pm
TPUK
y yes
Don't confuse TPUK (Transit Parts UK) in Wickford, Essex - Who are members on here.
With
Transit Parts Centre (GOLDEN LEAF FLOWERS LTD T/A TRANSIT PARTS) in New Southgate London :roll:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Tue Jan 19, 2016 7:59 pm
pushrod wrote:Changed the oil. That was easy, but had to bend my arm in about 6 places to change the filter... :roll:
Remove O/S front wheel gives you easier access to oil filter 8)
paul2012
Postby nokivasara » Tue Jan 19, 2016 8:26 pm
I don't think 6 bends are enough if you have the Eberspächer heater installed. I'm almost thinking about relocating the filter...
Yesterday I had to take a heat gun and run around the rear doors, all doors except one front door were frozen shut. Happy days :roll:
Then I put on the battery charger, was down to 3 leds of 8 on the charger so it was due.
Today on the way home there was some imbalance from the rear wheels, don't know if I have lost a balancing weight or if the rear shocks were frozen. We've had a few weeks of arctic winter weather now and the van is starting to complain...Which reminds me that I need to fix the air con before summer, there's a leak somewhere inside the fender. If I don't fix that I will be the one complaining when it get hot :mrgreen:
Transit Connect TDCI 110
nokivasara
Postby pushrod » Tue Jan 19, 2016 10:17 pm
I know, but it was already up on the ramps... :(
pushrod
Postby mrtn » Sat Jan 23, 2016 3:25 pm
Changed 3 of 4 glow plugs. The fourth one was behind the oil stick assembly which I noticed leaking from the bottom attachment so I need to remove it some day, fully. Took me 3 hours for the whole job, had to dremel off the tips of the plug contacts (too rusty to turn) and the hands froze to the point of no compliance (-6C outside).
Started right up with just a second of hesitation. Two plugs were dead, one looked healthy.
mrtn
Postby nokivasara » Sat Jan 23, 2016 3:52 pm
Noticed that the left rear door didn't close at the bottom, went to adjust the striker but they aren't adjustable??
No elongated holes on the striker and the latch itself is flush with the inner door skin so that cant be moved either.
Am I missing something?
Also tried to hoist down the spare wheel but nothing happened when I turned the screw under the plug, threw in one of the summer wheels in the back of the van and made a mental note to fix the spare wheel when it gets warmer...
nokivasara
Postby Graham Taylor » Thu Jan 28, 2016 6:00 pm
Did a bit more to the white van
Fitted new skid plates front & rear painted in gloss black also colour coded and fitted US style mirrors.
Graham Taylor
