What did you do to your connect today?
Re: What did you do to your connect today?
Postby Graham Taylor » Fri Mar 18, 2016 3:46 pm
trixyben wrote:Tried to fit an egr blanking plate and failed
Not a hope either of the bolts were going to move
Ah well i gave it a shot, still bugs me though i couldnt get it fitted :oops:
Good dose of wd40 over a couple of days usually works.
Graham Taylor
Postby mrtn » Sun Mar 20, 2016 5:28 pm
Upgraded front speakers on the Tourneo Connect (GAS 13 cm, 160W), full sound insulation for both - sheet metal and plastic door card. 6h in the garage.
1.6 Ecoboost A/T LWB '16
mrtn
Postby shedrool83 » Sun Mar 20, 2016 6:02 pm
Fitted newer style rear lights
shedrool83
Postby mrtn » Mon Mar 21, 2016 5:00 pm
Put up a sales ad.
mrtn
Postby nokivasara » Mon Mar 21, 2016 6:01 pm
Looked at new tires, thinking of getting 195/70-15 C tires, maybe they fit me better, I drive a lot on gravel roads and the tread wear on normal tires is quite shocking.
Seems to be bigger selection of coarser tread patterns too on the C tires.
Transit Connect TDCI 110
nokivasara
Postby mrtn » Mon Mar 21, 2016 9:03 pm
mrtn
Postby teldec » Sat Mar 26, 2016 11:19 pm
took it to ford for a major service
teldec
Postby pushrod » Sun Mar 27, 2016 12:18 pm
Cleaned out the back, fishing tackle; stuff that may be useful, but never is; spare wheel with wrong tyre; dried mud!
Fitted "new" carpet - a rather fetching blue. :D
Fitted ring bolts for luggage straps.
pushrod
Postby Graham Taylor » Thu Mar 31, 2016 1:30 pm
New twin tailpipe fitted, should be good for another 20bhp :lol: :lol: :lol:
Graham Taylor
Postby Custard Kid » Fri Apr 01, 2016 10:12 pm
fitted new front bumper, nice simple task really
Custard Kid
Postby ucmanster » Fri Apr 01, 2016 10:22 pm
I have problem with my rear brake calopiers. Did some of you have some problems with rear disc brakes too? my hand brake doesen't wokrk at all.... almost...did some of you solved similar problems? an how much it cost?
-i was lookin for a renovable calipers and it cost around 150€ fo each side. It 300£ for both and it's a lot.... I think.... :)
ucmanster
Postby mrtn » Fri Apr 01, 2016 10:46 pm
I've replaced the handbrake cable once, it just got jammed.
mrtn
Postby ucmanster » Sat Apr 02, 2016 7:15 am
mrtn wrote:I've replaced the handbrake cable once, it just got jammed.
I did raplaced cable too. Bur it is stil no good. :(
ucmanster
Postby Milemuncher » Sat Apr 02, 2016 9:23 am
We also have problems with the handbrake on our Connect. We have owned it about 3 years and the handbrake has always been poor.
Usually because one or the other calliper sticks off. The van is seldom used and kept in the concrete garage and this is making the problem worse (slightly damp over winter), obviously have to leave the handbrake off in the garage as once it got stuck on in there.
I just wish the van had drum brakes on the rear and not discs, as it has cost a lot of money like you. Have had both callipers replaced and a cable. Each service the mechanic cleans and greases the sliders and it works for a few months.
Milemuncher
Postby ucmanster » Sat Apr 02, 2016 6:20 pm
Milemuncher wrote:We also have problems with the handbrake on our Connect. We have owned it about 3 years and the handbrake has always been poor.
So, you say that problem is repeating? Even after you replaced callipers?
ucmanster
