NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Fri Dec 27, 2013 9:49 pm
rennie wrote:
paul2012 wrote:Hopefully rear bumper will be ready to pick up tomorrow :D
Decided to order new trim for centre floor console.
Paul,will there be enough left in the pot for some new pedal rubbers? :lol:
They do look abit worn :oops:
New ones are pennies, so will be replaced at some point - proberly as a finishing touch :lol: 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Mon Dec 30, 2013 9:30 pm
New rear bumper now painted :D
If you're wondering what the extra holes towards bottom are for ? - They are for lower trim 8)
Parking sensors & Lower trim fitted.
Sensor loom fitted.
paul2012
Postby ishmail » Tue Dec 31, 2013 12:04 am
hi mate just letting you know that i just got my new parking sensor from this guy for only £14 i know it says for volvo but its the same thing it works on mine :Dhttp://www.ebay.co.uk/itm/281207775922? ... 1439.l2649
ishmail
Postby paul2012 » Tue Dec 31, 2013 9:21 pm
ishmail wrote:hi mate just letting you know that i just got my new parking sensor from this guy for only £14 i know it says for volvo but its the same thing it works on mine :Dhttp://www.ebay.co.uk/itm/281207775922? ... 1439.l2649
Thank m8 got mine from Ford :wink:
paul2012
Postby looneyfitter » Tue Dec 31, 2013 10:25 pm
Pm sent matey
I WILL GET THIS FEcKER RUNNING!!!
looneyfitter
Postby paul2012 » Thu Jan 02, 2014 8:11 pm
Finally fitted rear bumper this afternoon.
Forgot to get towing eye cap painted :oops:
Changed out rear ABS sensor loom for one with rear parking sensor sub loom
Parking sensors are now working as they should do :D
paul2012
Postby ishmail » Thu Jan 02, 2014 8:47 pm
paul2012 wrote:Finally fitted rear bumper this afternoon.
damn i'm so jealous lol she looks great i love it :shock:
ishmail
Postby paul2012 » Fri Jan 03, 2014 12:00 am
:mrgreen: 8)
There's not much more to do to finish
paul2012
Postby looneyfitter » Fri Jan 03, 2014 12:44 am
You could always sell it then do a mk7
looneyfitter
Postby ishmail » Fri Jan 03, 2014 2:41 am
is that exhaust pipe between your legs lol i know i said she looks great but no need to go that far :lol: :lol: :lol: :lol:
ishmail
Postby paul2012 » Fri Jan 03, 2014 5:25 am
ishmail wrote:Image
:shock: :lol: :lol:
Exhaust tail pipe is across my chest :wink:
paul2012
Postby paul2012 » Fri Jan 03, 2014 8:26 pm
Went to calibrate steering angle sensor today only to find out it's faulty :evil:
Still having problems with RCM (Air bag module) Air bag light proves out ok but then comes back on.
Airbag is ok also the 2012 drivers seatbelt pre-tensioner with the wiring & added for it is fine.
This time DTC B1881 is stored - Passenger-side pre-tensioner circuit open / resistance high :?
It looks like I may require a 2009 onwards passenger seatbelt after all - Although wiring I grabbed for driver side part wiring was also there for passenger side , but taped back to loom with no yellow plug.
I will have to check passenger seatbelt in the connect I removed wiring from to see if it's connected or not.
paul2012
Postby paul2012 » Tue Jan 07, 2014 11:40 pm
Bagged a brand new steering angle sensor from ebay £15 :mrgreen:
Now time to remove faulty one. First remove complete column switch gear assembly from steering column.
Remove 4 screws securing squib to switch gear body & lift clear.
On the back is were steering angle sensor clipped to squib.
Unclip & remove sensor.
Fit new steering angle sensor in it's place.
Refit squib to switch gear body & refit assembly to steering column.
Sensor has now been calibrated via Ford IDS & working properly. :D
PS - Steering angle on Transit mk7's is fitted in the same way :wink:
paul2012
Postby paul2012 » Wed Jan 08, 2014 8:47 pm
Refitted column switchgear assembly with new steering angle sensor & it's now working perfectly :D
After checking connect at breakers yard where I obtained O/S seat belt wiring from, I can confirm N/S seatbelt also has a pretensioner.
Which is surprising as 2003-2009 connects don't have a N/S pretensioner with only a drivers airbag.
So I grabbed seatbelt & wiring to go with it & fitted to my connect. Now airbag system is fully working with no DTC's & airbag light proves out & stays off as it should do :D
Also bagged GEM module & alarm wiring, bonnet switch & horn. Hopefull I should be able to fit it into my connect.
Don't know if auto wipe/lights is enabled on GEM module though, I know there's no options to enable then via IDS :(
Hopefully I can find a way to reprogram GEM module so it has Alarm & automatic wipers / headlights enabled :?
I will know more tomorrow....
paul2012
Postby rickyconnect » Thu Jan 09, 2014 1:17 pm
The van is looking good :) just wanted to ask will any ford sensors work ? And if I have disconnected my angle sensor will it need re programming by ford ? Thanks
rickyconnect
