What did you do to your connect today?
Re: What did you do to your connect today?
Postby DevonMike » Wed Nov 09, 2022 6:12 pm
Today I decided to embark on the replacement of the front and rear anti roll bar bushes and drop links.
I'd firstly like to say the rear bushes were a piece of cake, there was only 1 awkward bolt which was obstructed by the fuel tank, another weird thing about the rear bushes, was you had to cut them, and bend them open to get them over the anti roll bar.
The front bushes are a little harder and that involves dropping the sub frame, in order for you to undo the rear clamp bolts (especially on the drivers side) all in all, not a tragic job.
But WOW what a difference, its weird driving the van in complete silence, not having a rattling banging symphony from the front and the rear.
DevonMike
Postby mrtn » Wed Dec 14, 2022 9:01 pm
Bought a litre of Ford OEM coolant to top off my complaining Connect's expansion tank. Got a Ford calendar with the purchase, not sure where to hang it. Haven't used an analog calendar for years.
1.6 Ecoboost A/T LWB '16
mrtn
Postby Kenton » Sat Feb 18, 2023 11:22 pm
Had two new front tyres fitted. Went for the new Hankook Ventus S1 Evo3's. Replaced thermostat and housing, MOT done for another year. Not bad for a Saturday morning / afternoon 8) 18 years, 156k and still rolling sweet. Next two jobs for following Saturday; replace reversing light switch, and fuel metering valve (already purchased) :D
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Vannycraddock » Fri Jun 23, 2023 9:48 am
Had a f*** nightmare in the old girl.......
Snapped a gear selector cable leaving the van in 3rd, about 10 miles from home, managed to get back to the mechanic only for him to say he's fully booked for the next 3 weeks.
He said he could order the parts and use his tools etc if I wanted to have a go myself.
So yesterday I stripped out the old cables and replaced them with new ones. So todays plan is put the rest of the bits back in the engine bay and see if my novice mechanic skills did the trick!
Whilst it was a total pain in the arse there's something rewarding about working on your own van!
Oh and install some 6x9s into the back
Vannycraddock
Postby Altransit » Fri Jun 23, 2023 10:56 am
Vannycraddock wrote:So yesterday I stripped out the old cables and replaced them with new ones. So todays plan is put the rest of the bits back in the engine bay and see if my novice mechanic skills did the trick!
Well done you for having a go :D 8)
Postby Vannycraddock » Fri Jun 23, 2023 3:51 pm
Thanks dude!
Turns out I did a spiffing job, van back together and ready to rock, although the mechanics lad has totally wrecked my sill trying to jack it up from there.
Turns out it had a crisp outer shell with a soft and gooey centre.
Got the speakers done too, in hindsight I should've put them at the back facing the driver instead of the ply lining firing at each other, but it does fill it out quite nicely.
Vannycraddock
Postby Johnathan » Sun Apr 07, 2024 8:42 pm
Hi, I bought a set of wheels and tyres from a Connect Active. Wasnt sure they would fit but they were cheap so took a punt, so happy it worked out :D
Johnathan
Postby mrtn » Sat Apr 13, 2024 3:30 pm
Cam belt and water pump replacement at 164Mm, new rear discs/pads plus handbrake cables. Feels fresh.
EDIT: aaand a new battery. Finally installed the quick connect socket on the terminals to make battery charger hookup easier.
mrtn
Postby painter4 » Sat Jul 27, 2024 2:39 pm
Not been here for a while , but on my 2011 connect I had to replace acceleration pedal today ,as the old one was causing over reving between gears , was an easy fix , but £107 from Ford....
painter4
Postby CLOVERLEAF159 » Fri Nov 22, 2024 6:19 pm
had to have a new screen fitted today to our Tourneo after a some stone flew up and cracked the screen. went through insurance and paid my £115 excess but the guy was telling me the screens cost over £1000 as they are heated. :shock: is that true?
CLOVERLEAF159
Postby g-man » Wed Dec 04, 2024 6:10 pm
CLOVERLEAF159 wrote:had to have a new screen fitted today to our Tourneo after a some stone flew up and cracked the screen. went through insurance and paid my £115 excess but the guy was telling me the screens cost over £1000 as they are heated. :shock: is that true?
Which model, I’ve got a mk1 that could with changing, half the elements have packed, just needs a self inflicted stone chip in the right spot lol
g-man
Postby mrtn » Thu Dec 12, 2024 1:19 am
LostinTransit wrote:mark, I don't need your opinion or honesty as I've had you on ignore since day one.. you need to avoid my topics in the future as I post them anywhere I can that might benefit others. if none of my post benefit you then I would avoid them in the future. It would seem i'm the only one here that is actually creating a build and i'm NOT having any issues with doing so, while others are bitchin about something breaking or not starting..
To quote your "performance" page:
Flord Performance
This is Our Taboo Transit Connect Performance
Build & It's Been Banned By All The Transit
Connect Forums, Hotrod Forums, Racing Forums
& Performance Car Forums
Nobody has banned you from anything. You have ragequit yourself because you cannot withstand other people in the same space with you. People with a different opinion even more so.
I have seen this circus happen for a decade (in various internet message boards) and you have remained the same exact self-centric bully.
Mark's suggestion was spot on. I just hope you don't actually end up over there.
mrtn
Postby mrtn » Tue Dec 17, 2024 9:50 am
LostinTransit wrote:mrtn you've been a thorn in my side since 2015, go f*** yourself..
Seems you have ragequit your own medium blog.
mrtn
Postby SteveRSF » Fri Jan 03, 2025 7:19 am
Insulating ,boarding and carpet fitted over the past few days
SteveRSF
Postby Altransit » Sat Aug 16, 2025 4:40 pm
Thread has been edited and hopefully restored to its original purpose instead of a one-man blog 8) :P :mrgreen:
Users browsing this forum: metalworker0
